Fixed Rank Kriging for Cellular Coverage Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Vehicular Technology Année : 2016
Coverage planning and optimization is one of the most crucial tasks for a radio network operator. Efficient coverage optimization requires accurate coverage estimation. This estimation relies on geo-located field measurements which are gathered today during highly expensive drive tests (DT); and will be reported in the near future by users' mobile devices thanks to the 3GPP Minimizing Drive Tests (MDT) feature [1]. This feature consists in an automatic reporting of the radio measurements associated with the geographic location of the user's mobile device. Such a solution is still costly in terms of battery consumption and signaling overhead. Therefore, predicting the coverage on a location where no measurements are available remains a key and challenging task. This paper describes a powerful tool that gives an accurate coverage prediction on the whole area of interest: it builds a coverage map by spatially interpolating geo-located measurements using the Kriging technique. The paper focuses on the reduction of the computational complexity of the Kriging algorithm by applying Fixed Rank Kriging (FRK). The performance evaluation of the FRK algorithm both on simulated measurements and real field measurements shows a good trade-off between prediction efficiency and computational complexity. In order to go a step further towards the operational application of the proposed algorithm, a multicellular use-case is studied. Simulation results show a good performance in terms of coverage prediction and detection of the best serving cell.
BrahamJemaaMoulinesTVT2016.pdf (3.95 Mo) Télécharger le fichier
hal-01418961 , version 1 (17-12-2016)
Hajer Braham, Sana Ben Jemaa, Gersende Fort, Éric Moulines, Berna Sayrac. Fixed Rank Kriging for Cellular Coverage Analysis. IEEE Transactions on Vehicular Technology, 2016, pp.11. ⟨10.1109/TVT.2016.2599842⟩. ⟨hal-01418961⟩
473 Consultations
270 Téléchargements
