Inverse Protein Folding Problem via Quadratic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a method of reconstruction a primary structure of a protein that folds into a given geometrical shape. This method predicts the primary structure of a protein and restores its linear sequence of amino acids in the polypeptide chain using the tertiary structure of a molecule. Unknown amino acids are determined according to the principle of energy minimization. This study represents inverse folding problem as a quadratic optimization problem and uses different relaxation techniques to reduce it to the problem of convex optimizations. Computational experiment compares the quality of these approaches on real protein structures.
Riazanov2016InverseProteinFoldingProblem.pdf (345.32 Ko) Télécharger le fichier
hal-01419374 , version 1 (19-12-2016)
hal-01419374 , version 2 (03-01-2017)
Paternité - Pas d'utilisation commerciale - Pas de modification
Andrii Riazanov, Mikhail Karasikov, Sergei Grudinin. Inverse Protein Folding Problem via Quadratic Programming. Information Technology and Systems 2016, Sep 2016, Repino, St. Petersburg, Russia. pp.561-568. ⟨hal-01419374v2⟩
854 Consultations
280 Téléchargements
