Lexicographical Order in Integer Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Vietnam Journal of Mathematics Année : 2016
Forcing lexicographical order in the solutions to an integer programming problem is a possible strategy to avoid symmetric solutions. An orbisack is the convex hull of the lexicographically ordered pairs of n-dimensional binary vectors. In this paper, we present a minimal complete description of orbisacks. In addition, we provide a polynomial formulation with exponential coefficients and a formulation with an exponential number of constraints but with unit coefficients, both of which still force lexicographical order. An exact separation procedure is also described.
Fichier non déposé
hal-01419551 , version 1 (19-12-2016)
Martine Labbé, Alfredo Marín, Antonio M. Rodríguez-Chía. Lexicographical Order in Integer Programming. Vietnam Journal of Mathematics, 2016, ⟨10.1007/s10013-016-0220-0⟩. ⟨hal-01419551⟩
115 Consultations
0 Téléchargements
