J. Bérenger, A perfectly matched layer for the absorption of electromagnetic waves, Journal of Computational Physics, vol.114, issue.2, pp.185-200, 1994.
DOI : 10.1006/jcph.1994.1159
J. Bérenger, Three-Dimensional Perfectly Matched Layer for the Absorption of Electromagnetic Waves, Journal of Computational Physics, vol.127, issue.2, pp.363-379, 1996.
DOI : 10.1006/jcph.1996.0181
E. Bécache, S. Fauqueux, and P. Joly, Stability of perfectly matched layers, group velocities and anisotropic waves, Journal of Computational Physics, vol.188, issue.2, pp.399-433, 2003.
DOI : 10.1016/S0021-9991(03)00184-0
E. Bécache, P. Joly, and V. Vinoles, On the analysis of perfectly matched layers for a class of dispersive media. application to negative index metamaterials. Submitted . URL https
E. Bécache and M. Kachanovska, Stable perfectly matched layers for a class of anisotropic dispersive models. Part I: Necessary and sufficient conditions of stability. Submitted. URL https
A. Welters, Y. Avniel, and S. G. Johnson, Speed-of-light limitations in passive linear media, Physical Review A, vol.90, issue.2, p.23847, 2014.
DOI : 10.1103/PhysRevA.90.023847
E. Bécache and P. Joly, On the analysis of B??renger's Perfectly Matched Layers for Maxwell's equations, ESAIM: Mathematical Modelling and Numerical Analysis, vol.36, issue.1, pp.87-119, 2002.
DOI : 10.1051/m2an:2002004
L. Zhao and A. C. Cangellaris, GT-PML: generalized theory of perfectly matched layers and its application to the reflectionless truncation of finite-difference time-domain grids, IEEE Transactions on Microwave Theory and Techniques, vol.44, issue.12, pp.2555-2563, 1996.
DOI : 10.1109/22.554601
T. Hagstrom and D. Appelö, Automatic Symmetrization and Energy Estimates Using Local Operators for Partial Differential Equations, Communications in Partial Differential Equations, vol.253, issue.7, pp.1129-1145, 2007.
DOI : 10.1017/CBO9780511662850
D. Appelö, T. Hagstrom, and G. Kreiss, Perfectly Matched Layers for Hyperbolic Systems: General Formulation, Well???posedness, and Stability, SIAM Journal on Applied Mathematics, vol.67, issue.1, pp.1-23, 2006.
DOI : 10.1137/050639107
E. Bécache, P. Joly, M. Kachanovska, ´. E. Bécache, P. Joly et al., Stable perfectly matched layers for a cold plasma in a strong background magnetic field. Submitted. URL https Perfectly matched layers in negative index metamaterials and plasmas, CANUM 2014?42e Congrès National d'Analyse Numérique of ESAIM Proc. Surveys, EDP Sci, pp.113-132, 2015.
M. Cassier, P. Joly, and M. Kachanovska, On properties of passive systems In preparation
E. Bécache and M. Kachanovska, Stable perfectly matched layers for a class of anisotropic dispersive models. Part I. Necessary and Sufficient Conditions of Stability. Extended Version. URL https
J. Diaz and P. Joly, A time domain analysis of PML models in acoustics, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.29-32, pp.29-32, 2006.
DOI : 10.1016/j.cma.2005.02.031
URL : https://hal.archives-ouvertes.fr/inria-00410313
E. Bécache, P. G. Petropoulos, and S. D. Gedney, On the Long-Time Behavior of Unsplit Perfectly Matched Layers, IEEE Transactions on Antennas and Propagation, vol.52, issue.5, pp.1335-1342, 2004.
DOI : 10.1109/TAP.2004.827253
S. Ervedoza and E. Zuazua, Perfectly matched layers in 1-d : energy decay for continuous and semi-discrete waves, Numerische Mathematik, vol.78, issue.5, pp.597-634, 2008.
DOI : 10.1007/s00211-008-0153-y
URL : https://hal.archives-ouvertes.fr/hal-00681710
Y. Huang, J. Li, and W. Yang, Mathematical analysis of a PML model obtained with stretched coordinates and its application to backward wave propagation in metamaterials, Numerical Methods for Partial Differential Equations, vol.11, issue.5
DOI : 10.1002/num.21824
M. Kachanovska, A note on the stability of PMLs for a class of anisotropic dispersive models in corners
A. Bamberger, B. Cockburn, Y. Goldman, M. Kern, and P. Joly, Numerical solution of Maxwell's equations in a conductive and polarizable medium, Proceedings of the Eighth International Conference on Computing Methods in Applied Sciences and Engineering, pp.11-25, 1987.
DOI : 10.1016/0045-7825(89)90011-X
B. Cockburn and P. Joly, Maxwell Equations in Polarizable Media, SIAM Journal on Mathematical Analysis, vol.19, issue.6, pp.1372-1390, 1988.
DOI : 10.1137/0519101
A. Figotin and J. H. Schenker, Spectral Theory of Time Dispersive and Dissipative Systems, Journal of Statistical Physics, vol.57, issue.723, pp.199-263, 2005.
DOI : 10.1007/s10955-004-8783-7
