A 3-D upwind Euler solver for unstructured meshes AIAA paper 91-1548CP Aspects of unstructured grids and finite volume solvers for the Euler and Navier- Stokes equations, Special Course on Unstructured Grid Methods for advection Dominated Flows, AGARD report 787, 1991. ,
Numerical Methods and Error Estimation for Conservation laws on Structured and Unstructured Meshes. VKI Computational Fluid Dynamics Lecture Series, 2003. ,
Finite Volume Methods: Foundation and Analysis, Encyclopedia of Computational Mechanics, 2004. ,
DOI : 10.1002/0470091355.ecm010
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.6.403
Surf Similarity, Coastal Engineering 1974, pp.446-480, 1974. ,
DOI : 10.1061/9780872621138.029
Experimental investigation of wave propagation over a bar, Coastal Engineering, vol.19, issue.1-2, p.151, 1993. ,
DOI : 10.1016/0378-3839(93)90022-Z
Upwind schemes for the two-dimensional shallow water equations with variable depth using unstructured meshes, Computer Methods in Applied Mechanics and Engineering, vol.155, issue.1-2, p.49, 1998. ,
DOI : 10.1016/S0045-7825(97)85625-3
URL : https://hal.archives-ouvertes.fr/inria-00073955
A reasoned overview on Boussinesq-type models: the interplay between physics, mathematics and numerics, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.13, issue.2160, 2013. ,
DOI : 10.1098/rspa.2013.0496
Zero mass error using unsteady wetting???drying conditions in shallow flows over dry irregular topography, International Journal for Numerical Methods in Fluids, vol.45, issue.10, pp.1047-1082, 2004. ,
DOI : 10.1002/fld.729
A numerical model for the flooding and drying of irregular domain The numerical treatment of wet/dry fronts in shallow flows: Application to one-layer and two-layer systems, Int. J. Numer. Meth. Fluids Mathematical and Computer Modelling, vol.39, issue.42, pp.247419-439, 2002. ,
A robust high-resolution finite volume scheme for the simulation of long waves over complex domains, International Journal for Numerical Methods in Fluids, vol.29, issue.4, pp.419-452, 2008. ,
DOI : 10.1002/fld.1537
Performance and Comparison of Cell-Centered and??Node-Centered Unstructured Finite Volume Discretizations for??Shallow Water Free Surface Flows, Archives of Computational Methods in Engineering, vol.38, issue.7, pp.57-118, 2011. ,
DOI : 10.1007/s11831-011-9057-6
An integral contravariant formulation of the fully non-linear Boussinesq equations, Coastal Engineering, vol.83, pp.119-136, 2014. ,
DOI : 10.1016/j.coastaleng.2013.09.006
A flexible genuinely nonlinear approach for nonlinear wave propagation, breaking and run-up, Journal of Computational Physics, vol.310, pp.381-417, 2016. ,
DOI : 10.1016/j.jcp.2016.01.027
Computer solution of Large Sparce Positive Definite Systems, N.J, 1981. ,
Hyperbolic systems of conservation laws, Applied Mathematical Sciences, vol.118, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-00113734
Directional Nearshore Wave Propagation Over a Rip Channel: An Experiment, Coastal Engineering 1992, 1992. ,
DOI : 10.1061/9780872629332.017
Applications of a boussinesq wave model, International Conference on Estuariew and Coasts, 2003. ,
Flux Difference Splitting and the Balancing of Source Terms and Flux Gradients, Journal of Computational Physics, vol.165, issue.1, pp.89-125, 2000. ,
DOI : 10.1006/jcph.2000.6603
An unstructured finite volume numerical scheme for extended 2D Boussinesq-type equations, Coastal Engineering, vol.69, pp.42-66, 2012. ,
DOI : 10.1016/j.coastaleng.2012.05.008
Numerical treatment of wave breaking on unstructured finite volume approximations for extended Boussinesq-type equations, Journal of Computational Physics, vol.271, pp.281-305, 2014. ,
DOI : 10.1016/j.jcp.2014.01.030
Boussinesq Modeling of Wave Transformation, Breaking, and Runup.???I: 1D, Journal of Waterway, Port, Coastal, and Ocean Engineering, vol.126, issue.1, pp.39-47, 2000. ,
DOI : 10.1061/(ASCE)0733-950X(2000)126:1(39)
Boussinesq Models and Their Application to Coastal Processes across a Wide Range of Scales, Journal of Waterway, Port, Coastal, and Ocean Engineering, vol.142, issue.6, p.2016 ,
DOI : 10.1061/(ASCE)WW.1943-5460.0000350
High-Order Boussinesq-Type Model for Integrated Nearshore Dynamics, Journal of Waterway, Port, Coastal, and Ocean Engineering, vol.142, issue.6, pp.142-2016 ,
DOI : 10.1061/(ASCE)WW.1943-5460.0000349
Adaptive quadtree simulation of shallow flows with wet???dry fronts over complex topography, Computers & Fluids, vol.38, issue.2, pp.221-234, 2009. ,
DOI : 10.1016/j.compfluid.2008.02.008
Observation of the directional spectrum of sea waves using the motions of a floating buoy, Proc. Conf. of Ocean Wave Spectra, 1961. ,
Nearshore Wave Modeling with High-Order Boussinesq-Type Equations, Journal of Waterway, Port, Coastal, and Ocean Engineering, vol.132, issue.5, pp.348-357, 2006. ,
DOI : 10.1061/(ASCE)0733-950X(2006)132:5(348)
A new form of the Boussinesq equations with improved linear dispersion characteristics. Part 2. A slowly-varying bathymetry, Coastal Engineering, vol.18, issue.3-4, pp.183-204, 1992. ,
DOI : 10.1016/0378-3839(92)90019-Q
Surf zone dynamics simulated by a Boussinesq type model. Part II: surf beat and swash oscillations for wave groups and irregular waves, Coastal Engineering, vol.32, issue.4, pp.289-319, 1997. ,
DOI : 10.1016/S0378-3839(97)00029-X
Frequency down-shift of swash oscillations compared to incident waves, Journal of Hydraulic Research, vol.33, issue.3, pp.397-411, 1995. ,
DOI : 10.1017/S0022112063000628
An unstructured node-centered finite volume scheme for shallow water flows with wet/dry fronts over complex topography, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.47-48, pp.3723-3750, 2009. ,
DOI : 10.1016/j.cma.2009.08.006
Alternative Form of Boussinesq Equations for Nearshore Wave Propagation, Journal of Waterway, Port, Coastal, and Ocean Engineering, vol.119, issue.6, pp.618-638, 1994. ,
DOI : 10.1061/(ASCE)0733-950X(1993)119:6(618)
Long waves on a beach, Journal of Fluid Mechanics, vol.13, issue.04, pp.815-882, 1967. ,
DOI : 10.1017/S0022112067002605
Stabilized residual distribution for shallow water simulations, Journal of Computational Physics, vol.228, issue.4, pp.1071-1115, 2009. ,
DOI : 10.1016/j.jcp.2008.10.020
URL : https://hal.archives-ouvertes.fr/inria-00538892
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.457.5978
Shock-capturing Boussinesq-type model for nearshore wave processes, Coastal Engineering, vol.57, issue.4, pp.407-423, 2010. ,
DOI : 10.1016/j.coastaleng.2009.11.007
Iterative Methods for Sparse Linear Systems, 1996. ,
DOI : 10.1137/1.9780898718003
A Boussinesq model for waves breaking in shallow water, Coastal Engineering, vol.20, issue.3-4, pp.185-202, 1993. ,
DOI : 10.1016/0378-3839(93)90001-O
Comparison of Reconstruction Techniques for Unstructured Mesh Vertex Centered Finite Volume Schemes, 18th AIAA Computational Fluid Dynamics Conference, pp.1-22, 2007. ,
DOI : 10.2514/6.2007-3958
Surf zone dynamics simulated by a Boussinesq type model. III. Wave-induced horizontal nearshore circulations, Coastal Engineering, vol.33, issue.2-3, pp.155-176, 1998. ,
DOI : 10.1016/S0378-3839(98)00007-6
Boussinesq-type modelling using an unstructured finite element technique, Coastal Engineering, vol.50, issue.4, p.182, 2004. ,
DOI : 10.1016/j.coastaleng.2003.10.005
A New Class of Optimal High-Order Strong-Stability-Preserving Time Discretization Methods, SIAM Journal on Numerical Analysis, vol.40, issue.2, p.469, 2002. ,
DOI : 10.1137/S0036142901389025
A new approach to handle wave breaking in fully non-linear Boussinesq models, Coastal Engineering, vol.67, pp.54-66, 2012. ,
DOI : 10.1016/j.coastaleng.2012.04.004
URL : https://hal.archives-ouvertes.fr/hal-00798996
Hybrid finite volume ??? finite difference scheme for 2DH improved Boussinesq equations, Coastal Engineering, vol.56, issue.5-6, pp.609-620, 2009. ,
DOI : 10.1016/j.coastaleng.2009.01.001
Finite volume scheme for the solution of 2D extended Boussinesq equations in the surf zone, Ocean Engineering, vol.37, issue.7, pp.567-582, 2010. ,
DOI : 10.1016/j.oceaneng.2010.02.004
Shock-capturing Boussinesq model for irregular wave propagation, Coastal Engineering, vol.61, pp.8-19, 2012. ,
DOI : 10.1016/j.coastaleng.2011.11.006
A Comparative Study of Computational Methods in Cosmic Gas Dynamics, Astron. Astrophysics, vol.108, pp.46-84, 1982. ,
DOI : 10.1007/978-3-642-60543-7_6
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, Journal of Computational Physics, vol.32, issue.1, p.101, 1979. ,
DOI : 10.1016/0021-9991(79)90145-1
WAFO -A Matlab Toolbox for Analysis of Random Waves and Loads -A Tutorial, Math. Stat., Center for Math. Sci, 2000. ,
Generation of waves in Boussinesq models using a source function method, Coastal Engineering, vol.36, issue.4, p.271, 1999. ,
DOI : 10.1016/S0378-3839(99)00009-5
A numerical study of three dimensional breaking waves and turbulence effects, 2004. ,
Depth-integrated, non-hydrostatic model for wave breaking and run-up, Inria RESEARCH CENTRE BORDEAUX ? SUD-OUEST 200 avenue de la Vieille Tour 33405 Talence Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria.fr ISSN, pp.473-0249, 2009. ,
DOI : 10.1029/2007GL030158
