Formal semantics of behavior specifications in the architecture analysis and design language standard - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In system design, an architecture specification or model serves, among other purposes, as a repository to share knowledge about the system being designed. Such a repository enables automatic generation of analytical models for different aspects relevant to system design (timing, reliability, security, etc.). The Architecture Analysis and Design Language (AADL) is a standard proposed by SAE to express architecture specifications and share knowledge between the different stakeholders about the system being designed. To support unambiguous reasoning, formal verification, high-fidelity simulation of architecture specifications in a model-based AADL design workflow, we have defined a formal semantics for the behavior specification of the AADL, the presentation of this semantics is the aim of this paper.
hldvt16.pdf (527.03 Ko) Télécharger le fichier
hal-01419968 , version 1 (20-12-2016)
Loïc Besnard, Thierry Gautier, Clément Guy, Paul Le Guernic, Jean-Pierre Talpin, et al.. Formal semantics of behavior specifications in the architecture analysis and design language standard. HLDVT 2016 - 18th IEEE International High-Level Design Validation and Test Workshop, Oct 2016, Santa Cruz, United States. pp.30-39, ⟨10.1109/HLDVT.2016.7748252⟩. ⟨hal-01419968⟩
893 Consultations
223 Téléchargements
