A new approach for Bayesian model averaging, Science China Earth Sciences, vol.115, issue.8, pp.10-10007, 2011. ,
DOI : 10.1007/s11430-011-4307-x
Determinants of Economic Growth: Will Data Tell? American Economic Journal: Macroeconomics, forthcoming, 2010. ,
DOI : 10.1257/mac.2.4.222
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.118.7501
Accelerating Markov chainMonteCarlosimulationbyself-adaptivedifferentialevolutionwithrandomizedsubspacesampling, Int J Nonlinear Sci Numer Simul, 2008. ,
Treatment of input uncertainty in hydrologic modeling: Doing hydrology backward with Markov chain Monte Carlo simulation, Water Resources Research, vol.33, issue.3, pp.10-1029, 2008. ,
DOI : 10.1029/2007WR006720
Combining multi-objective optimization and Bayesian model averaging to calibrate forecast ensembles of soil hydraulic models, Water Resour Res, vol.doi, pp.10-1029, 2008. ,
An integrated hydrologic Bayesian multimodel combination framework: Confronting input, parameter, and model structural uncertainty in hydrologic prediction, Water Resources Research, vol.204, issue.6, pp.10-1029, 2007. ,
DOI : 10.1029/2005WR004745
Using Bayesian Model Averaging to Calibrate Forecast Ensembles, Monthly Weather Review, vol.133, issue.5 ,
DOI : 10.1175/MWR2906.1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.142.9558
Sorooshian Multi-model combination techniques for hydrological forecasting: application to distributed model intercomparison project results, J Hydrometeorol, vol.8, pp.755-768, 2006. ,
DOI : 10.1175/jhm519.1
Model-Robust Process Optimization Using Bayesian Model Averaging, Technometrics, vol.47, issue.2, pp.152-163, 2005. ,
DOI : 10.1198/004017005000000120
An approach for improving the sampling efficiency in the Bayesian calibration of computationally expensive simulation models A dual-pass variational data assimilation framework for estimating soil moisture profiles from AMSR-E microwave brightness temperature, Water Resour. Res. J. Geophys. Res, vol.45, pp.10-102910, 1029. ,
A microwave land data assimilation system: Scheme and preliminary evaluation over China, Journal of Geophysical Research, vol.58, issue.D17, pp.10-1029, 2010. ,
DOI : 10.1029/2010JD014370
