Conference papers
Study on Key Technology for the Discrimination of Xihu Longjing Tea Grade by Electronic Tongue
Abstract : Electronic tongue has the characteristics of sensitivity and instability. However the technical specification for its research has still not been formed. In this paper, it was introduced the key technology of electronic tongue qualitative discriminant analysis to micro-difference samples. The research objects were four different grades of Xihu Longjing Tea with less difference within small producing area in Hangzhou of Zhejiang Province in China. According to the research, the stability of equipment had not been shown until the fifth repetition for the same sample by the electronic tongue. Finally, the signal from seventh repetitive test was selected to represent the intelligent taste fingerprint for this sample. The fingerprints of electronic tongue collected at different days showed linearity drifting for the same sample. The special tea samples were set into each series of experiments to be considered as the reference sample. All samples’ signals were calibrated with the difference value between the reference sample fingerprint of corresponding test to the designated reference sample. Principal component analysis (PCA) results showed that the same grade samples were clustered, while the different grades samples were more dispersion and non-overlapping. Through Mahalanobis Distance and Residual Method, the four abnormal tea samples were rejected from highest and 1st grade respectively. The electronic tongue’s Longjing Tea Grade models were built by soft independent modeling of class analogy (SIMCA). The discrimination accuracy for tea sample grade were both 100% for correction set and prediction set. Through this study, it was established the technical specification and flow for the quick detection of tea by electronic tongue, which including the determination on intelligent taste spectrum repeatability performance, system error calibration for spectrum drifting, rejection for abnormal tea sample based on taste spectrum and establishment for the quality judgment model . The technical specification provides the theoretical base for reasonable use of electronic tongue.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01420254
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, December 20, 2016 - 2:04:10 PM
Last modification on : Thursday, January 14, 2021 - 4:36:03 PM
Long-term archiving on: : Monday, March 20, 2017 - 6:10:50 PM
File
978-3-319-19620-6_43_Chapter.p...
Identifiers
Citation
Bolin Shi, Houyin Wang, Lei Zhao, Ruicong Zhi, Zhi Li, et al.. Study on Key Technology for the Discrimination of Xihu Longjing Tea Grade by Electronic Tongue. 8th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2014, Beijing, China. pp.379-392, ⟨10.1007/978-3-319-19620-6_43⟩. ⟨hal-01420254⟩
Share
Metrics
Record views
54
Files downloads
83
