Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Design of a Measurement and Control System for Delinting Machine
Abstract : To improve the working efficiency of cottonseed delinting machine, an automated measurement and control system for the machine is designed. The system hardware is comprised of three torque sensor, master controller, data acquisition and regulation module, displacement transducer, linear actuator and variable frequency device. The operating parameters such as the rotation torque and speed of every delinting cylinder and outlet opening are obtained on line by the apparatus and then sent to the master controller. With the help of LabWindow/CVI, the master controller program is developed to get and deal with the information. Since the feed rate and discharge rate directly affect the working load of the cylinders, the speed of feeding motor and outlet opening can be manually regulated by means of the program to facilitate the working load test experiment. In order to achieve the optimization load allocation of the delinting cylinder, the optimal decision is made on the basis of the third cylinder’s working load to regulate the outlet opening. The experiment results show that the outlet opening regulation accuracy reaches ±1mm.This system is also easy to use and provide a good graphical user interface and has higher accuracy, higher efficiency for the real-time control.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01420283
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, December 20, 2016 - 2:05:22 PM
Last modification on : Thursday, March 5, 2020 - 4:42:28 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 1:56:24 PM
File
978-3-319-19620-6_72_Chapter.p...
Identifiers
Citation
Liming Zhou, yanwei yuan, Junning Zhang, Xin Dong. Design of a Measurement and Control System for Delinting Machine. 8th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2014, Beijing, China. pp.646-652, ⟨10.1007/978-3-319-19620-6_72⟩. ⟨hal-01420283⟩
Share
Metrics
Record views
56
Files downloads
189
