Computing discrete logarithms in F 3 6·137 and F 3 6·163 using Magma, Arithmetic of Finite Fields, p.322, 2014. ,
DOI : 10.1007/978-3-319-16277-5_1
A subexponential algorithm for the discrete logarithm problem with applications to cryptography, 20th Annual Symposium on Foundations of Computer Science (sfcs 1979), p.5560, 1979. ,
DOI : 10.1109/SFCS.1979.2
The function eld sieve, Algorithmic Number Theory (ANTS-I), p.141154, 1994. ,
Function eld sieve method for discrete logarithms over nite elds, Information and Computation, vol.151, issue.12, p.516, 1999. ,
Imperfect Forward Secrecy, Proceedings of the 22nd ACM SIGSAC Conference on Computer and Communications Security, CCS '15, p.517, 2015. ,
DOI : 10.1145/2810103.2813707
URL : https://hal.archives-ouvertes.fr/hal-01184171
fplll-4.0, a oating-point LLL implementation ,
Polynomial Selection for the Number Field Sieve, 2011. ,
Root optimization of polynomials in the number eld sieve, Mathematics of Computation, vol.84, issue.295, p.24472457, 2015. ,
Algorithmes de logarithmes discrets dans les corps nis, 2013. ,
Discrete logarithm in GF(2 809 ) with FFS, PKC 2014: 17th International Conference on Theory and Practice of Public Key Cryptography, p.221238, 2014. ,
DOI : 10.1007/978-3-642-54631-0_13
URL : https://hal.archives-ouvertes.fr/hal-00818124
Improving NFS for the discrete logarithm problem in non-prime nite elds, Advances in Cryptology EUROCRYPT 2015, Part I, p.129155, 2015. ,
A heuristic quasi-polynomial algorithm for discrete logarithm in nite elds of small characteristic, Advances in Cryptology EUROCRYPT 2014, pp.116-125 ,
The tower number eld sieve, Advances in Cryptology ASI- ACRYPT 2015, p.3155, 2015. ,
Abstract, LMS Journal of Computation and Mathematics, vol.17, issue.A, p.230246, 2014. ,
DOI : 10.1017/CBO9781139856065
Constructing elliptic curves with prescribed embedding degrees, Security in Communication Networks, p.257267, 2002. ,
Pairing-friendly elliptic curves of prime order, Selected Areas in Cryptography (SAC 2005), p.319331, 2006. ,
Computing small discrete logarithms faster, Progress in Cryptology INDOCRYPT 2012, p.317338, 2012. ,
Non-uniform cracks in the concrete: The power of free precomputation, Advances in Cryptology ASIACRYPT 2013, p.321340, 2013. ,
On the Correct Use of the Negation Map in the Pollard rho Method, Public Key Cryptography PKC 2011, p.128146, 2011. ,
DOI : 10.1007/978-3-642-19379-8_8
Bounds for resultants of univariate and bivariate polynomials, Linear Algebra and its Applications, vol.432, issue.8, 2009. ,
DOI : 10.1016/j.laa.2009.08.012
Baby-step giant-step algorithms for nonuniform distributions, Algorithmic Number Theory (ANTS- IV), volume 1838 of Lecture Notes in Computer Science, p.153168, 2000. ,
Computing logarithms in nite elds of characteristic two, SIAM Journal on Algebraic Discrete Methods, vol.5, issue.2, p.276285, 1984. ,
Computing logarithms in GF(2 n ), Advances in Cryptology, Proceedings of CRYPTO '84, p.7382, 1984. ,
Short signatures from the Weil pairing, Advances in Cryptology ASIACRYPT 2001, p.514532, 2001. ,
Algorithmes pour la factorisation d'entiers et le calcul de logarithme discret, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01167281
An improved Monte Carlo factorization algorithm, BIT, vol.17, issue.2, p.176184, 1980. ,
DOI : 10.1007/BF01933190
Elliptic curves suitable for pairing based Discrete Logarithms, pp.9-37 ,
DOI : 10.1007/s10623-004-3808-4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.6.3813
Factoring integers with the number eld sieve The Development of the Number Field Sieve, Lecture Notes in Mathematics, vol.1554, p.5094, 1993. ,
On a problem of Oppenheim concerning "factorisatio numerorum, Journal of Number Theory, vol.17, issue.1, p.128, 1983. ,
Réduction de réseau et sécurité concrète du chirement complètement homomorphe, 2013. ,
Speeding up the pollard rho method on prime elds, Advances in Cryptology ASIACRYPT 2008, p.471488, 2008. ,
Supersingular hyperelliptic curves of genus 2 over nite elds, Journal of Applied Mathematics and Computation, vol.163, issue.2, p.565576, 2005. ,
An algorithm to solve the discrete logarithm problem with the number eld sieve, Public Key Cryptography PKC 2006, p.174190, 2006. ,
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, p.333350, 1994. ,
DOI : 10.2307/2153413
Fast evaluation of logarithms in elds of characteristic two, IEEE Transactions on Information Theory, vol.30, issue.4, p.587594, 1984. ,
Modications to the number eld sieve, Journal of Cryptology, vol.6, issue.3, p.169180, 1993. ,
Discrete logarithms in GF(p), Algorithmica, vol.1, issue.1, p.115, 1986. ,
New directions in cryptography, IEEE Transactions on Information Theory, vol.22, issue.6, p.644654, 1976. ,
Speeding up the discrete log computation on curves with automorphisms, Advances in Cryptology ASIACRYPT '99, p.103121, 1999. ,
Attacking elliptic curve cryptosystems using the parallel Pollard rho method, CryptoBytes, vol.4, 1999. ,
Random Mapping Statistics, Advances in Cryptology EURO- CRYPT '89, p.329354, 1990. ,
DOI : 10.1007/3-540-46885-4_34
URL : https://hal.archives-ouvertes.fr/inria-00075445
DL record in F 3 6·97 of 923 bits (278 dd) NICT press release, 2012. ,
Quasi-polynomial-time algorithm for discrete logarithm in nite elds of small/medium characteristic. The Elliptic Curve Cryptography blog, 2013. ,
Supersingular curves in cryptography, Lecture Notes in Computer Science, vol.2248, pp.495513-495522, 2001. ,
Recent progress on the elliptic curve discrete logarithm problem, Cryptology ePrint Archive, 1022. ,
An improvement to the Gaudry-Schost algorithm for multidimensional discrete logarithm problems, Cryptography and Coding, p.368382, 2009. ,
Using equivalence classes to accelerate solving the discrete logarithm problem in a short interval, Public Key Cryptography PKC 2010, p.368383, 2010. ,
Computing elliptic curve discrete logarithms with improved baby-step giant-step algorithm. Cryptology ePrint Archive, 2015. ,
A Low-Memory Parallel Version of Matsuo, Chao, and Tsujii???s Algorithm, Algorithmic Number Theory (ANTS-VI), p.208222, 2004. ,
DOI : 10.1007/978-3-540-24847-7_15
Discrete logarithms in GF(p) using the number eld sieve, SIAM Journal on Discrete Mathematics, vol.6, issue.1, p.124138, 1993. ,
Breaking '128-bit secure' supersingular binary curves -(or how to solve discrete logarithms in F 2 4·1223 and F 2 12·367 ), Advances in Cryptology CRYPTO 2014, Part II, p.126145, 2014. ,
Discrete logarithms in GF, 2014. Announcement available at the NMBRTHRY archives, p.9234 ,
Breaking pairing-based cryptosystems using ? T pairing over GF(3 97 ), Advances in Cryptology ASIACRYPT 2012, p.4360, 2012. ,
DOI : 10.1007/978-3-642-34961-4_5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.261.3190
Solving a 676-bit discrete logarithm problem in GF, p.6 ,
The eciency of solving multiple discrete logarithm problems and the implications for the security of xed elliptic curves, International Journal of Information Security, vol.3, issue.2, p.8698, 2004. ,
Extended tower number eld sieve with application to nite elds of arbitrary composite extension degree, Cryptology ePrint Archive, 2016. ,
Faster index calculus for the medium prime case application to 1175-bit and 1425-bit nite elds, Advances in Cryptology EUROCRYPT 2013, p.177193, 2013. ,
A New Index Calculus Algorithm with Complexity $$L(1/4+o(1))$$ in Small Characteristic, Selected Areas in Cryptography SAC 2013, p.355379, 2014. ,
DOI : 10.1007/978-3-662-43414-7_18
The function eld sieve is quite special, Algorithmic Number Theory, p.431445, 2002. ,
DOI : 10.1007/3-540-45455-1_34
Improvements to the general number eld sieve for discrete logarithms in prime elds. A comparison with the Gaussian integer method, Mathematics of Computation, issue.242, p.72953967, 2003. ,
The function eld sieve in the medium prime case, Advances in Cryptology EUROCRYPT 2006, p.254270, 2006. ,
The number eld sieve in the medium prime case, Advances in Cryptology CRYPTO 2006, p.326344 ,
Improving the polynomial time precomputation of frobenius representation discrete logarithm algorithms -simplied setting for small characteristic nite elds, Advances in Cryptology ASIACRYPT 2014, p.378397, 2014. ,
The special number eld sieve in F p n -application to pairing-friendly constructions, Pairing-Based Cryptography Pairing 2013, p.4561, 2014. ,
Nearly sparse linear algebra. Cryptology ePrint Archive, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01154879
An upper bound on the number of monomials in determinants of sparse matrices with symbolic entries, Mathematica Pannonica, vol.8, p.7382, 1997. ,
Subset-Restricted Random Walks for Pollard rho Method on ${\mathbf{F}_{p^m}}$, Public Key Cryptography PKC 2009, p.5467, 2009. ,
DOI : 10.1007/978-3-642-00468-1_4
Extended tower number eld sieve: A new complexity for the medium prime case, Advances in Cryptology CRYPTO 2016, Part I, Lecture Notes in Computer Science, p.543571, 2016. ,
On polynomial selection for the general number eld sieve, Mathematics of Computation, vol.75, issue.256, p.20372047, 2006. ,
DOI : 10.1090/s0025-5718-06-01870-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.8539
Polynomial selection Invited talk at the CADO-NFS workshop, 2008. ,
Discrete logarithms in GF Announcement available at the NMBRTHRY archives, 1279. ,
Another look at non-standard discrete log and Die-Hellman problems, Journal of Mathematical Cryptology, vol.2, issue.4, p.311326, 2008. ,
DOI : 10.1515/jmc.2008.014
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.215.1664
Recherches sur la Théorie des Nombres, GauthierVillars, 1924. ,
Random Walks Revisited: Extensions of Pollard???s Rho Algorithm for Computing Multiple Discrete Logarithms, Selected Areas in Cryptography, pp.212229-212238, 2001. ,
DOI : 10.1007/3-540-45537-X_17
Unbelievable security: Matching AES security using public key systems (invited talk), Advances in Cryptology ASI- ACRYPT 2001, p.6786, 2001. ,
Key lengths, Handbook of Information Security, p.617635, 2006. ,
Factoring polynomials with rational coecients, Mathematische Annalen, vol.261, issue.4, p.515534, 1982. ,
Selecting cryptographic key sizes, Journal of Cryptology, vol.14, issue.4, p.255293, 2001. ,
Eective version of the number eld sieve for discrete logarithms in the eld GF(p k ) (in Russian), Trudy po Discretnoi Matematike, vol.9, p.121151, 2006. ,
The relationship between breaking the Die- Hellman protocol and computing discrete logarithms, SIAM Journal on Computing, vol.28, issue.5, p.16891721, 1999. ,
The Die-Hellman protocol. Designs, Codes and Cryptography, p.147171, 2000. ,
The discrete logarithm problem, Cryptology and Computational Number Theory of Proceedings of Symposia in Applied Mathematics, p.4974, 1990. ,
DOI : 10.1090/psapm/042/1095551
Reducing elliptic curves logarithms to logarithms in a nite eld, IEEE Transactions on Information Theory, vol.39, issue.5, p.16391646, 1993. ,
DOI : 10.1109/18.259647
Characterization of Elliptic Curve Traces Under FR-Reduction, Lecture Notes in Computer Science, vol.2015, p.90108, 2000. ,
DOI : 10.1007/3-540-45247-8_8
Speeding the Pollard and elliptic curve methods of factorization, Mathematics of Computation, vol.48, issue.177, p.243264, 1987. ,
Polynomial Selection for the Number Field Sieve Integer Factorisation Algorithm, 1999. ,
Modelling the yield of number eld sieve polynomials, Algorithmic Number Theory: Third International Symposiun, ANTS-III Portland, p.137150, 1998. ,
Discrete logarithms in nite elds and their cryptographic significance, Advances in Cryptology EUROCRYPT '84, p.224314, 1985. ,
Determining strengths for public keys used for exchanging symmetric keys. Request for Comments RFC 3766, 2004. ,
DOI : 10.17487/rfc3766
The multiple number eld sieve with conjugation and generalized jouxlercier methods, Advances in Cryptology EUROCRYPT 2015, p.156170, 2015. ,
Monte Carlo methods for index computation (mod p) Mathematics of Computation, p.918924, 1978. ,
Kangaroos, Monopoly and Discrete Logarithms, Journal of Cryptology, vol.13, issue.4, pp.9-41 ,
DOI : 10.1007/s001450010010
On the discrete logarithm in the divisor class group of curves, Mathematics of Computation, vol.68, issue.226, p.805806, 1999. ,
DOI : 10.1090/S0025-5718-99-01043-1
New complexity trade-os for the (multiple) number eld sieve algorithm in non-prime elds. Cryptology ePrint Archive, 2015. ,
A general polynomial selection method and new asymptotic complexities for the tower number eld sieve algorithm, Cryptology ePrint Archive, 2016. ,
A generalisation of the conjugation method for polynomial selection for the extended tower number eld sieve algorithm, Cryptology ePrint Archive, vol.537, 2016. ,
Tower number eld sieve variant of a recent polynomial selection method. Cryptology ePrint Archive, 2016. ,
Fermat quotients and the polynomial time discrete log algorithm for anomalous elliptic curves, p.8192, 1998. ,
Generating random walks in groups, Ann. Univ. Sci. Budapest. Sect. Comput, vol.6, p.6579, 1985. ,
Discrete Logarithms and Local Units, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.345, issue.1676, p.409423, 1676. ,
DOI : 10.1098/rsta.1993.0139
Class number, a theory of factorization, and genera, Number Theory Institute of Proceedings of Symposia in Applied Mathematics, p.415440, 1969. ,
DOI : 10.1090/pspum/020/0316385
Polynomial-time algorithms for prime factorization and discrete logarithms on a quantum computer, SIAM Journal on Computing, vol.26, issue.5, p.14841509, 1997. ,
The Discrete Logarithm Problem on Elliptic Curves of Trace One, Journal of Cryptology, vol.12, issue.3, p.193196, 1999. ,
DOI : 10.1007/s001459900052
Optimized baby stepgiant step methods, J. Ramanujan Math. Soc, vol.20, issue.1, p.2758, 2005. ,
Cryptography: Theory and Practice. Discrete Mathematics and Its Applications, 2006. ,
CADO-NFS, an implementation of the number eld sieve algorithm ,
A modication of Shanks' baby-step giant-step algorithm, Mathematics of Computation, vol.69, issue.230, p.767773, 2000. ,
Speeding up Pollard's rho method for computing discrete logarithms, Algorithmic Number Theory (ANTS-III), volume 1423 of Lecture Notes in Computer Science, p.541554, 1998. ,
DOI : 10.1007/BFb0054891
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.36.9419
Computation of Discrete Logarithms in $$ \mathbb{F}_{2^{607} } $$, Advances in Cryptology ASIACRYPT 2001, p.107124, 2001. ,
DOI : 10.1007/3-540-45682-1_7
Discrete logarithms in GF(2 607 ) Announcement available at the NMBRTHRY archives, 2002. ,
Algorithmes de calcul de logarithme discret dans les corps nis, Thèse, École polytechnique, 2003. ,
Parallel collision search with cryptanalytic applications, Journal of Cryptology, vol.12, issue.1, p.128, 1999. ,
Tables of Indices and Primitive Roots, Royal Society Mathematical Tables, vol.9, 1968. ,
Solving sparse linear equations over nite elds, IEEE Transactions on Information Theory, vol.32, issue.1, p.5462, 1986. ,
DOI : 10.1109/tit.1986.1057137
Discrete Logarithm Problem in Degree Six Finite Fields, 2008. ,
