Computing Discrete Logarithms in $${\mathbb F}_{3^{6 \cdot 137}}$$ and $${\mathbb F}_{3^{6 \cdot 163}}$$ Using Magma, Arithmetic of Finite Fields, pp.3-22, 2014. ,
DOI : 10.1007/978-3-319-16277-5_1
A subexponential algorithm for the discrete logarithm problem with applications to cryptography, 20th Annual Symposium on Foundations of Computer Science (sfcs 1979), pp.55-60, 1979. ,
DOI : 10.1109/SFCS.1979.2
The function field sieve, Algorithmic Number Theory (ANTS-I), pp.141-154, 1994. ,
DOI : 10.1007/3-540-58691-1_48
Function field sieve method for discrete logarithms over finite fields, Information and Computation, vol.151, issue.12, pp.5-16, 1999. ,
Imperfect Forward Secrecy, Proceedings of the 22nd ACM SIGSAC Conference on Computer and Communications Security, CCS '15, pp.5-17, 2015. ,
DOI : 10.1007/3-540-68339-9_29
URL : https://hal.archives-ouvertes.fr/hal-01184171
fplll-4.0, a floating-point LLL implementation ,
Polynomial Selection for the Number Field Sieve, 2011. ,
Root optimization of polynomials in the number field sieve, Mathematics of Computation, vol.84, issue.295, pp.2447-2457, 2015. ,
DOI : 10.1090/S0025-5718-2015-02926-3
URL : https://hal.archives-ouvertes.fr/hal-00919367
Algorithmes de logarithmes discrets dans les corps finis, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-00925228
Discrete Logarithm in GF(2809) with FFS, PKC 2014: 17th International Conference on Theory and Practice of Public Key Cryptography, pp.221-238, 2014. ,
DOI : 10.1007/978-3-642-54631-0_13
URL : https://hal.archives-ouvertes.fr/hal-00818124
Improving NFS for the Discrete Logarithm Problem in Non-prime Finite Fields, Advances in Cryptology ? EUROCRYPT 2015, pp.129-155, 2015. ,
DOI : 10.1007/978-3-662-46800-5_6
URL : https://hal.archives-ouvertes.fr/hal-01112879
A Heuristic Quasi-Polynomial Algorithm for Discrete Logarithm in Finite Fields of Small Characteristic, Advances in Cryptology ? EUROCRYPT 2014, pp.1-16 ,
DOI : 10.1007/978-3-642-55220-5_1
URL : https://hal.archives-ouvertes.fr/hal-00835446
The Tower Number Field Sieve, Advances in Cryptology ? ASI- ACRYPT 2015, pp.31-55, 2015. ,
DOI : 10.1007/978-3-662-48800-3_2
URL : https://hal.archives-ouvertes.fr/hal-01155635
Abstract, LMS Journal of Computation and Mathematics, vol.17, issue.A, pp.230-246, 2014. ,
DOI : 10.1017/CBO9781139856065
Constructing elliptic curves with prescribed embedding degrees, Security in Communication Networks, pp.257-267, 2002. ,
Pairing-friendly elliptic curves of prime order, Selected Areas in Cryptography (SAC 2005), pp.319-331, 2006. ,
Computing small discrete logarithms faster, Progress in Cryptology ? INDOCRYPT 2012, pp.317-338, 2012. ,
Non-uniform cracks in the concrete: The power of free precomputation, Advances in Cryptology ? ASIACRYPT 2013, pp.321-340, 2013. ,
On the Correct Use of the Negation Map in the Pollard rho Method, Public Key Cryptography ? PKC 2011, pp.128-146, 2011. ,
DOI : 10.1007/978-3-642-19379-8_8
Bounds for resultants of univariate and bivariate polynomials, Linear Algebra and its Applications, vol.432, issue.8, pp.1995-2005, 2009. ,
DOI : 10.1016/j.laa.2009.08.012
Baby-step giant-step algorithms for nonuniform distributions, Algorithmic Number Theory (ANTS-IV), volume 1838 of Lecture Notes in Computer Science, pp.153-168, 2000. ,
Computing Logarithms in Finite Fields of Characteristic Two, SIAM Journal on Algebraic Discrete Methods, vol.5, issue.2, pp.276-285, 1984. ,
DOI : 10.1137/0605029
Computing Logarithms in GF (2n), Advances in Cryptology, Proceedings of CRYPTO '84, pp.73-82, 1984. ,
DOI : 10.1007/3-540-39568-7_8
Short Signatures from the Weil Pairing, Advances in Cryptology ? ASIACRYPT 2001, pp.514-532, 2001. ,
DOI : 10.1007/3-540-45682-1_30
Algorithmes pour la factorisation d'entiers et le calcul de logarithme discret, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01167281
An improved Monte Carlo factorization algorithm, BIT, vol.17, issue.2, pp.176-184, 1980. ,
DOI : 10.1007/BF01933190
Elliptic curves suitable for pairing based cryptography. Designs, Codes and Cryptography, pp.133-141, 2005. ,
Factoring integers with the number field sieve, Lecture Notes in Mathematics, vol.32, issue.107, pp.50-94, 1993. ,
DOI : 10.1109/TIT.1986.1057137
On a problem of Oppenheim concerning " factorisatio numerorum, Journal of Number Theory, vol.17, issue.1, pp.1-28, 1983. ,
Réduction de réseau et sécurité concrète du chiffrementcompì etement homomorphe, 2013. ,
Speeding Up the Pollard Rho Method on Prime Fields, Advances in Cryptology ? ASIACRYPT 2008, pp.471-488, 2008. ,
DOI : 10.1007/3-540-48892-8_15
Supersingular hyperelliptic curves of genus 2 over finite fields, Applied Mathematics and Computation, vol.163, issue.2, pp.565-576, 2005. ,
DOI : 10.1016/j.amc.2004.03.030
An Algorithm to Solve the Discrete Logarithm Problem with the Number Field Sieve, Public Key Cryptography ? PKC 2006, pp.174-190, 2006. ,
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
DOI : 10.2307/2153413
Fast evaluation of logarithms in fields of characteristic two, IEEE Transactions on Information Theory, vol.30, issue.4, pp.587-594, 1984. ,
DOI : 10.1109/TIT.1984.1056941
Modifications to the Number Field Sieve, Journal of Cryptology, vol.6, issue.3, pp.169-180, 1993. ,
DOI : 10.1007/BF00198464
Discrete logarithms inGF(p), Algorithmica, vol.13, issue.1-4, pp.1-15, 1986. ,
DOI : 10.6028/jres.045.026
New directions in cryptography, IEEE Transactions on Information Theory, vol.22, issue.6, pp.644-654, 1976. ,
DOI : 10.1109/TIT.1976.1055638
Speeding up the discrete log computation on curves with automorphisms, Advances in Cryptology ? ASIACRYPT '99, pp.103-121, 1999. ,
Attacking elliptic curve cryptosystems using the parallel Pollard rho method, CryptoBytes, vol.4, 1999. ,
Random Mapping Statistics, Advances in Cryptology ? EUROCRYPT '89, pp.329-354, 1990. ,
DOI : 10.1007/3-540-46885-4_34
URL : https://hal.archives-ouvertes.fr/inria-00075445
DL record in F 3 6·97 of 923 bits (278 dd) NICT press release, 2012. ,
Quasi-polynomial-time algorithm for discrete logarithm in finite fields of small/medium characteristic. The Elliptic Curve Cryptography blog, 2013. ,
Supersingular curves in cryptography, Advances in Cryptology ? ASIACRYPT 2001, pp.495-513, 2001. ,
Recent progress on the elliptic curve discrete logarithm problem, Cryptology ePrint Archive, 1022. ,
An improvement to the Gaudry-Schost algorithm for multidimensional discrete logarithm problems, Cryptography and Coding, pp.368-382, 2009. ,
Using equivalence classes to accelerate solving the discrete logarithm problem in a short interval, Public Key Cryptography ? PKC 2010, pp.368-383, 2010. ,
Computing elliptic curve discrete logarithms with improved baby-step giant-step algorithm. Cryptology ePrint Archive, 2015. ,
A Low-Memory Parallel Version of Matsuo, Chao, and Tsujii???s Algorithm, Algorithmic Number Theory (ANTS-VI), pp.208-222, 2004. ,
DOI : 10.1007/978-3-540-24847-7_15
Discrete logarithms in GF(p) using the number field sieve, SIAM Journal on Discrete Mathematics, vol.6, issue.1, pp.124-138, 1993. ,
Breaking ???128-bit Secure??? Supersingular Binary Curves, Advances in Cryptology ? CRYPTO 2014, Part II, pp.126-145, 2014. ,
DOI : 10.1007/978-3-662-44381-1_8
Discrete logarithms in GF, 2014. Announcement available at the NMBRTHRY archives, p.9234 ,
Breaking Pairing-Based Cryptosystems Using ?? T Pairing over GF(397), Advances in Cryptology ? ASIACRYPT 2012, pp.43-60, 2012. ,
DOI : 10.1007/978-3-642-34961-4_5
Solving a 676-Bit Discrete Logarithm Problem in GF(36n ), Public Key Cryptography ? PKC 2010, pp.351-367, 2010. ,
DOI : 10.1007/978-3-642-13013-7_21
The efficiency of solving multiple discrete logarithm problems and the implications for the security of fixed elliptic curves, International Journal of Information Security, vol.12, issue.2, pp.86-98, 2004. ,
Extended tower number field sieve with application to finite fields of arbitrary composite extension degree, Cryptology ePrint Archive, 2016. ,
Faster Index Calculus for the Medium Prime Case Application to 1175-bit and 1425-bit Finite Fields, Advances in Cryptology ? EUROCRYPT 2013, pp.177-193, 2013. ,
DOI : 10.1007/978-3-642-38348-9_11
A New Index Calculus Algorithm with Complexity $$L(1/4+o(1))$$ in Small Characteristic, Selected Areas in Cryptography ? SAC 2013, pp.355-379, 2014. ,
DOI : 10.1007/978-3-662-43414-7_18
The Function Field Sieve Is Quite Special, Algorithmic Number Theory (ANTS-V), volume 2369 of Lecture Notes in Computer Science, pp.431-445, 2002. ,
DOI : 10.1007/3-540-45455-1_34
URL : https://hal.archives-ouvertes.fr/hal-01102040
Improvements to the general number field sieve for discrete logarithms in prime fields. A comparison with the gaussian integer method, Mathematics of Computation, vol.72, issue.242, pp.953-967, 2003. ,
DOI : 10.1090/S0025-5718-02-01482-5
URL : https://hal.archives-ouvertes.fr/hal-01102016
The Function Field Sieve in the Medium Prime Case, Advances in Cryptology ? EUROCRYPT 2006, pp.254-270, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00456191
The Number Field Sieve in the Medium Prime Case, Advances in Cryptology ? CRYPTO 2006, pp.326-344 ,
DOI : 10.1007/11818175_19
URL : https://hal.archives-ouvertes.fr/hal-01102034
Improving the Polynomial time Precomputation of Frobenius Representation Discrete Logarithm Algorithms, Advances in Cryptology ? ASIACRYPT 2014, pp.378-397, 2014. ,
DOI : 10.1007/978-3-662-45611-8_20
URL : https://hal.archives-ouvertes.fr/hal-01213649
The Special Number Field Sieve in $\mathbb{F}_{p^{n}}$, Pairing-Based Cryptography ? Pairing 2013, pp.45-61, 2014. ,
DOI : 10.1007/978-3-319-04873-4_3
Nearly sparse linear algebra. Cryptology ePrint Archive, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01154879
An upper bound on the number of monomials in determinants of sparse matrices with symbolic entries, Mathematica Pannonica, vol.8, pp.73-82, 1997. ,
Subset-Restricted Random Walks for Pollard rho Method on ${\mathbf{F}_{p^m}}$, Public Key Cryptography ? PKC 2009, pp.54-67, 2009. ,
Extended Tower Number Field Sieve: A New Complexity for the Medium Prime Case, Advances in Cryptology ? CRYPTO 2016, Part I, Lecture Notes in Computer Science, pp.543-571, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01281966
On polynomial selection for the general number field sieve, Mathematics of Computation, vol.75, issue.256, pp.2037-2047, 2006. ,
DOI : 10.1090/S0025-5718-06-01870-9
Polynomial selection Invited talk at the CADO-NFS workshop, 2008. ,
Discrete logarithms in GF Announcement available at the NMBRTHRY archives, 1279. ,
Another look at non-standard discrete log and Diffie-Hellman problems, Journal of Mathematical Cryptology, vol.2947, issue.4, pp.311-326, 2008. ,
DOI : 10.1007/s00145-004-0328-3
Recherches sur la Théorie des Nombres, 1924. ,
Random Walks Revisited: Extensions of Pollard???s Rho Algorithm for Computing Multiple Discrete Logarithms, Selected Areas in Cryptography, pp.212-229, 2001. ,
DOI : 10.1007/3-540-45537-X_17
Unbelievable security: Matching AES security using public key systems (invited talk), Advances in Cryptology ? ASIACRYPT 2001, pp.67-86, 2001. ,
Key lengths, Handbook of Information Security, pp.617-635, 2006. ,
Factoring polynomials with rational coefficients, Mathematische Annalen, vol.261, issue.4, pp.515-534, 1982. ,
Selecting cryptographic key sizes, Journal of Cryptology, vol.14, issue.4, pp.255-293, 2001. ,
Effective version of the number field sieve for discrete logarithms in the field GF(p k ) (in Russian), Trudy po Discretnoi Matematike, vol.9, pp.121-151, 2006. ,
The relationship between breaking the Diffie- Hellman protocol and computing discrete logarithms, SIAM Journal on Computing, vol.28, issue.5, pp.1689-1721, 1999. ,
The Diffie-Hellman protocol. Designs, Codes and Cryptography, pp.147-171, 2000. ,
The discrete logarithm problem, Cryptology and Computational Number Theory, volume 42 of Proceedings of Symposia in Applied Mathematics, pp.49-74, 1990. ,
DOI : 10.1090/psapm/042/1095551
Reducing elliptic curve logarithms to logarithms in a finite field, IEEE Transactions on Information Theory, vol.39, issue.5, pp.1639-1646, 1993. ,
DOI : 10.1109/18.259647
Characterization of Elliptic Curve Traces Under FR-Reduction, Lecture Notes in Computer Science, vol.2015, pp.90-108, 2000. ,
DOI : 10.1007/3-540-45247-8_8
Speeding the Pollard and elliptic curve methods of factorization, Mathematics of Computation, vol.48, issue.177, pp.243-264, 1987. ,
Polynomial Selection for the Number Field Sieve Integer Factorisation Algorithm, 1999. ,
Modelling the yield of number field sieve polynomials Algorithmic Number Theory: Third International Symposiun, ANTS- III Portland, Proceedings, Lecture Notes in Computer Science, pp.137-150, 1998. ,
Discrete logarithms in finite fields and their cryptographic significance, Advances in Cryptology ? EUROCRYPT '84, pp.224-314, 1985. ,
Determining strengths for public keys used for exchanging symmetric keys. Request for Comments RFC 3766, 2004. ,
The Multiple Number Field Sieve with Conjugation and Generalized Joux-Lercier Methods, Advances in Cryptology ? EUROCRYPT 2015, pp.156-170, 2015. ,
DOI : 10.1007/978-3-662-46800-5_7
URL : https://hal.archives-ouvertes.fr/hal-01056205
Monte Carlo methods for index computation (mod p) Mathematics of Computation, pp.918-924, 1978. ,
Kangaroos, Monopoly and Discrete Logarithms, Journal of Cryptology, vol.13, issue.4, pp.437-447, 2000. ,
DOI : 10.1007/s001450010010
On the discrete logarithm in the divisor class group of curves, Mathematics of Computation, vol.68, issue.226, pp.805-806, 1999. ,
DOI : 10.1090/S0025-5718-99-01043-1
New complexity trade-offs for the (multiple) number field sieve algorithm in non-prime fields. Cryptology ePrint Archive, 2015. ,
A General Polynomial Selection Method and New Asymptotic Complexities for the Tower Number Field Sieve Algorithm, Cryptology ePrint Archive, vol.69, issue.231, 2016. ,
DOI : 10.1090/S0025-5718-99-01137-0
A generalisation of the conjugation method for polynomial selection for the extended tower number field sieve algorithm, Cryptology ePrint Archive, vol.537, 2016. ,
Tower number field sieve variant of a recent polynomial selection method. Cryptology ePrint Archive, 2016. ,
Fermat quotients and the polynomial time discrete log algorithm for anomalous elliptic curves, pp.81-92, 1998. ,
Generating random walks in groups, Ann. Univ. Sci. Budapest. Sect. Comput, vol.6, pp.65-79, 1985. ,
Discrete Logarithms and Local Units, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.345, issue.1676, pp.409-423, 1676. ,
DOI : 10.1098/rsta.1993.0139
Class number, a theory of factorization, and genera, of Proceedings of Symposia in Applied Mathematics, pp.415-440, 1969. ,
DOI : 10.1090/pspum/020/0316385
Polynomial-time algorithms for prime factorization and discrete logarithms on a quantum computer, SIAM Journal on Computing, vol.26, issue.5, pp.1484-1509, 1997. ,
The Discrete Logarithm Problem on Elliptic Curves of Trace One, Journal of Cryptology, vol.12, issue.3, pp.193-196, 1999. ,
DOI : 10.1007/s001459900052
Optimized baby step?giant step methods, J. Ramanujan Math. Soc, vol.20, issue.1, pp.27-58, 2005. ,
Cryptography: Theory and Practice. Discrete Mathematics and Its Applications, 2006. ,
CADO-NFS, an implementation of the number field sieve algorithm ,
A modification of Shanks' baby-step giant-step algorithm, Mathematics of Computation, vol.69, issue.230, pp.767-773, 2000. ,
Speeding up Pollard's rho method for computing discrete logarithms, Algorithmic Number Theory (ANTS-III), volume 1423 of Lecture Notes in Computer Science, pp.541-554, 1998. ,
DOI : 10.1007/BFb0054891
Computation of Discrete Logarithms in $$ \mathbb{F}_{2^{607} } $$, Advances in Cryptology ? ASIACRYPT 2001, pp.107-124, 2001. ,
DOI : 10.1007/3-540-45682-1_7
Discrete logarithms in GF(2 607 ) Announcement available at the NMBRTHRY archives, 2002. ,
Algorithmes de calcul de logarithme discret dans les corps finis, Thèse, ´ Ecole polytechnique, 2003. ,
Parallel collision search with cryptanalytic applications, Journal of Cryptology, vol.12, issue.1, pp.1-28, 1999. ,
Tables of Indices and Primitive Roots, Royal Society Mathematical Tables, vol.9, 1968. ,
Solving sparse linear equations over finite fields, IEEE Transactions on Information Theory, vol.32, issue.1, pp.54-62, 1986. ,
Discrete Logarithm Problem in Degree Six Finite Fields, 2008. ,
