A Rewrite System for Proof Constructivization
Proof constructivization is the problem of automatically extracting constructive proofs out of classical proofs. This process is required when classical theorem provers are integrated in intuitionistic proof assistants. We use the ability of rewrite systems to represent partial functions to implement heuristics for proof constructivization in Dedukti, a logical framework based on rewriting in which proofs are first-class objects which can be the subject of computation. We benchmark these heuristics on the proofs output by the automated theorem prover Zenon on the TPTP library of problems.
Logique en informatique [cs.LO]
