Synthesis Method for Matching Filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this paper is to develop an exact synthesis technique for matching filters in connexion with the use of single band antennas. A certified algorithm based on Youla's matching theory and convex optimization is presented. A practical example is considered with the synthesis of a matching filter in SIW technology used behind a microstrip patch antenna at 1.5 Ghz.
ims2017.pdf (660.62 Ko) Télécharger le fichier
IMS2017poster.pdf (1.15 Mo) Télécharger le fichier
Format : Poster
hal-01420636 , version 1 (06-03-2017)
David Martínez Martínez, Fabien Seyfert, Martine Olivi, Stéphane Bila, François Torres, et al.. Synthesis Method for Matching Filters. 2017 IEEE MTT-S International Microwave Symposium (IMS), Jun 2017, Honololu, United States. pp.1930-1933, ⟨10.1109/MWSYM.2017.8059040⟩. ⟨hal-01420636⟩
773 Consultations
533 Téléchargements
