Abstract : The programming environment FoCaLiZe allows the user to specify, implement, and prove programs with the help of the theorem prover Zenon. In the actual version, those proofs are verified by Coq. In this paper we propose to extend the FoCaLiZe compiler by a backend to the Dedukti language in order to benefit from Zenon Modulo, an extension of Zenon for Deduction modulo. By doing so, FoCaLiZe can benefit from a technique for finding and verifying proofs more quickly. The paper focuses mainly on the process that overcomes the lack of local pattern-matching and recursive definitions in Dedukti.
