Conference papers
ML Pattern-Matching, Recursion, and Rewriting: From FoCaLiZe to Dedukti
Abstract : The programming environment FoCaLiZe allows the user to specify, implement, and prove programs with the help of the theorem prover Zenon. In the actual version, those proofs are verified by Coq. In this paper we propose to extend the FoCaLiZe compiler by a backend to the Dedukti language in order to benefit from Zenon Modulo, an extension of Zenon for Deduction modulo. By doing so, FoCaLiZe can benefit from a technique for finding and verifying proofs more quickly. The paper focuses mainly on the process that overcomes the lack of local pattern-matching and recursive definitions in Dedukti.
Document type :
Conference papers
Complete list of metadatas
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01420638
Contributor : Raphaël Cauderlier <>
Submitted on : Tuesday, December 20, 2016 - 6:18:38 PM
Last modification on : Tuesday, July 7, 2020 - 11:52:47 AM
File
ICTAC_2016.pdf
Identifiers
Citation
Raphaël Cauderlier, Catherine Dubois. ML Pattern-Matching, Recursion, and Rewriting: From FoCaLiZe to Dedukti. ICTAC 2016 - 13th International Colloquium on Theoretical Aspects of Computing, Oct 2016, Taipei, Taiwan. pp.459-468, ⟨10.1007/978-3-319-46750-4_26⟩. ⟨hal-01420638⟩
Share
Metrics
Record views
270
Files downloads
462
