Projection under pairwise distance controls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Statistics - Theory and Methods Année : 2020
Projection sous les contrôles de distance par paires
Visualization of high-dimensional and possibly complex (non continuous for instance) data onto a low-dimensional space may be difficult. Several projection methods have been already proposed for displaying such high-dimensional structures on a lower-dimensional space, but the information lost is not always easy to use. Here, a new projection paradigm is presented to describe a non-linear projection method that takes into account the projection quality of each projected point in the reduced space, this quality being directly available in the same scale as this reduced space. More specifically, this novel method allows a straightforward visualization data in R 2 with a simple reading of the approximation quality, and provides then a novel variant of dimensionality reduction.
Paper_Projection Under pairwise distance Control.pdf (1.8 Mo) Télécharger le fichier
hal-01420662 , version 1 (20-12-2016)
hal-01420662 , version 2 (03-12-2017)
hal-01420662 , version 3 (10-12-2018)
hal-01420662 , version 4 (11-12-2019)
hal-01420662 , version 5 (23-12-2020)
Hiba Alawieh, Nicolas Wicker, Christophe Biernacki. Projection under pairwise distance controls. Communications in Statistics - Theory and Methods, 2020, ⟨10.1080/03610926.2020.1741626⟩. ⟨hal-01420662v5⟩
548 Consultations
293 Téléchargements
