New interface
Reports (Research report)
A Risk-based Approach to Privacy by Design (Extended Version)
Sourya Joyee De 1 Daniel Le Métayer 1, 2
1 PRIVATICS - Privacy Models, Architectures and Tools for the Information Society
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services, Inria Lyon
Abstract : The objective of the work described in this report is to help designers to select suitable architectures based on an incremental privacy risk analysis. We present a three-tier process including a generic privacy risk analysis depending on the specifications of the system and two refinements based on the architecture and the context respectively. We illustrate our approach with the design of a biometric access control system.
Document type :
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01420954
Contributor : Daniel Le Métayer Connect in order to contact the contributor
Submitted on : Wednesday, December 21, 2016 - 12:05:01 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:40 AM
Long-term archiving on: : Tuesday, March 21, 2017 - 9:11:05 AM
File
RR-9001.pdf
Identifiers
  • HAL Id : hal-01420954, version 1
Citation
Sourya Joyee De, Daniel Le Métayer. A Risk-based Approach to Privacy by Design (Extended Version). [Research Report] RR-9001, Inria - Research Centre Grenoble – Rhône-Alpes. 2016, pp.54. ⟨hal-01420954⟩
Share
Metrics
Record views
329
Files downloads
190
