Sampling the Fourier transform along radial lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2017
This article considers the use of total variation minimization for the recovery of a superposition of point sources from samples of its Fourier transform along radial lines. We present a numerical algorithm for the computation of solutions to this infinite dimensional problem. The theoretical results of this paper make precise the link between the sampling operator and the recoverability of the point sources.
hal-01421265 , version 1 (21-12-2016)
Charles H Dossal, Vincent Duval, Clarice Poon. Sampling the Fourier transform along radial lines. SIAM Journal on Numerical Analysis, 2017, 55 (6), ⟨10.1137/16M1108807⟩. ⟨hal-01421265⟩
377 Consultations
0 Téléchargements
