On the use of low rank approximations for sparse direct solvers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this talk, we describe a preliminary fast direct solver using HODLR library to compress large blocks appearing in the symbolic structure of the PaStiX sparse direct solver. We will present our general strategy before analyzing the practical gains in terms of memory and floating point operations with respect to a theoretical study of the problem. Finally, we will discuss the impact of reordering technic to enhance the low-rank compression.
Fichier non déposé
hal-01421376 , version 1 (22-12-2016)
  • HAL Id : hal-01421376 , version 1
Grégoire Pichon, Eric Darve, Mathieu Faverge, Pierre Ramet, Jean Roman. On the use of low rank approximations for sparse direct solvers. SIAM Annual Meeting (AN'16), Jul 2016, Boston, United States. ⟨hal-01421376⟩
242 Consultations
0 Téléchargements
