Vector borne diseases on an urban environment: the effects of heterogeneity and human circulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ecological Complexity Année : 2017
We study the effect of human circulation and host/vector heterogeneities on the onset of epidemics of arboviruses. From a meta-population dynamics based on the classical Bailey-Dietz model, we derive a multi-group model under three assumptions: (i) fast host sojourn timescale ; (ii) mosquitoes do not move; (iii) time homogeneity and strong connectivity of human circulation. Within this modelling framework, three different kinds of $R_0$ appear: (i) the " true " or " global " $R_0$ —derived from the corresponding next generation matrix; (ii) the uniform $R_0$—obtained if the patches are taken homogeneous; (iii) the local $R_0$s—obtained if the patches are disconnected. We show that there is relevant epidemiological information associated to all of them. In particular, they can be used to understand the effects of changing the circulation on the value of the global $R_0$. We also present additional results on the effects on $R_0$ of different vector control policies, and a simulation with data from the city of Rio de Janeiro, Brazil.
metapop_subHal.pdf (624.11 Ko) Télécharger le fichier
hal-01422432 , version 1 (25-12-2016)
Abderrahman Iggidr, Jair Koiller, Maria Lucia F. Penna, Gauthier Sallet, Moacyr Alvim Silva Silva, et al.. Vector borne diseases on an urban environment: the effects of heterogeneity and human circulation. Ecological Complexity, 2017, 30, pp.76--90. ⟨10.1016/j.ecocom.2016.12.006⟩. ⟨hal-01422432⟩
297 Consultations
344 Téléchargements
