On the accuracy of a stewart platform -part i, the effect of manufacturing tolerances, Proceedings of the IEEE International Conference on Robotics Automation, ICRA'93, 1993. ,
The kinematic error bound analysis of the Stewart platform, Journal of Robotic Systems, vol.17, issue.1, pp.63-73, 2000. ,
DOI : 10.1002/(SICI)1097-4563(200001)17:1<63::AID-ROB4>3.0.CO;2-R
Design Optimization of a Cartesian Parallel Manipulator, Journal of Mechanical Design, vol.124, issue.1, pp.43-51, 2003. ,
DOI : 10.1109/ROBOT.1997.606784
Kinematic sensitivity analysis of the 3-upu parallel mechanism, Mechanism and Machine Theory, pp.37-787, 2002. ,
Sensitivity analysis of the 3-PRS parallel kinematic spindle platform of a serial-parallel machine tool, International Journal of Machine Tools and Manufacture, vol.43, issue.15, pp.1561-1569, 2003. ,
DOI : 10.1016/S0890-6955(03)00202-5
Optimal Calibration of Parallel Kinematic Machines, Journal of Mechanical Design, vol.19, issue.1, pp.62-69, 2005. ,
DOI : 10.1016/S0007-8506(07)60827-0
Tolerance Synthesis of Mechanisms: A Robust Design Approach, Journal of Mechanical Design, vol.120, issue.1, pp.86-94, 2005. ,
DOI : 10.1080/15458830.1996.11770732
URL : https://hal.archives-ouvertes.fr/hal-00463707
Volumetric error analysis and architecture optimization for accuracy of hexaslide type parallel manipulators, Mechanism and Machine Theory, pp.227-240, 2003. ,
A General Approach for Geometric Error Modeling of Lower Mobility Parallel Manipulators, Journal of Mechanisms and Robotics, vol.2, issue.2, pp.210131-02101313, 2011. ,
DOI : 10.1115/1.533542
Are parallel robots more accurate than serial robots, Transactions of the Canadian Society for, Mechanical Engineering, vol.31, issue.4, pp.445-455, 2007. ,
Outils algbriques pour la rsolution de problmes gomtriques et l'analyse de trajectoire de robots parallles prvus pour des applications haute cadence et grande prcision, 2002. ,
Volumetric Error Analysis of a Stewart Platform-Based Machine Tool, CIRP Annals, vol.46, issue.1, pp.287-290, 1997. ,
Geometric approach to the accuracy analysis of a class of 3-dof planar parallel robots, Mechanism and Machine Theory, pp.364-375, 2009. ,
Design and analysis of a 3-ppr planar robot with u-shape base, Proceedings of the 14th International Conference on Advanced Robotics, 2009. ,
Parallel robots, 2000. ,
DOI : 10.1007/978-94-010-9587-7
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
Sensitivity Analysis of the Orthoglide: A Three-DOF Translational Parallel Kinematic Machine, Journal of Mechanical Design, vol.23, issue.2, pp.392-402, 2006. ,
DOI : 10.1109/TRA.2003.810242
Sensitivity Analysis of 3-RPR Planar Parallel Manipulators, Journal of Mechanical Design, vol.105, issue.12, pp.121005-121006, 2009. ,
DOI : 10.1115/1.2779893
URL : https://hal.archives-ouvertes.fr/hal-00456135
Sensitivity analysis of parallel manipulators using an interval linearization method, Mechanism and Machine Theory, pp.93-114, 2014. ,
Finding the Maximal Pose Error in Robotic Mechanical Systems Using Constraint Programming, Proceedings of IEA-AIE 2010, pp.82-91, 2010. ,
DOI : 10.1007/978-3-642-13022-9_9
URL : https://hal.archives-ouvertes.fr/hal-00462935
Dombre, Modeling, Identification and Control of Robots, 2002. ,
Assembly mode changing in parallel mechanisms, Robotics, IEEE Transactions on, vol.24, issue.4, pp.765-772, 2008. ,
Optimal Force Generation in Parallel Manipulators for Passing through the Singular Positions, The International Journal of Robotics Research, vol.7, issue.1, pp.967-983, 2008. ,
DOI : 10.1115/1.2406093
The Newton-Kantorovich Theorem, The American Mathematical Monthly, vol.75, issue.6, pp.658-660, 1968. ,
DOI : 10.2307/2313800
Optimal Error Bounds for the Newton???Kantorovich Theorem, SIAM Journal on Numerical Analysis, vol.11, issue.1, pp.10-13, 1974. ,
DOI : 10.1137/0711002
ON THE NEWTON???KANTOROVICH THEOREM, Analysis and Applications, vol.3, issue.03, pp.249-269, 2012. ,
DOI : 10.1007/978-1-4612-0985-0
URL : https://hal.archives-ouvertes.fr/hal-01077282
A new framework for sharp and efficient resolution of NCSP with manifolds of solutions, Constraints, vol.34, issue.2, pp.190-212, 2010. ,
DOI : 10.1137/1.9780898719468
URL : https://hal.archives-ouvertes.fr/hal-00480819
Certified Parallelotope Continuation for One-Manifolds, SIAM Journal on Numerical Analysis, vol.51, issue.6, pp.3373-3401, 2013. ,
DOI : 10.1137/130906544
URL : https://hal.archives-ouvertes.fr/hal-01408525
Interval-based projection method for under-constrained numerical systems, Constraints, vol.8, issue.5, pp.432-460, 2012. ,
DOI : 10.1023/A:1020505620702
URL : https://hal.archives-ouvertes.fr/hal-00868023
A Branch and Prune Algorithm for the Computation of Generalized Aspects of Parallel Robots, Artificial Intelligence, vol.221, pp.34-50, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00868073
The Krawczyk operator and Kantorovich's theorem, Journal of Mathematical Analysis and Applications, vol.149, issue.2, pp.437-443, 1990. ,
DOI : 10.1016/0022-247X(90)90053-I
URL : https://doi.org/10.1016/0022-247x(90)90053-i
Contractor programming, Contractor Programming, pp.1079-1100, 2009. ,
DOI : 10.1016/j.artint.2009.03.002
URL : https://hal.archives-ouvertes.fr/hal-00428957
Inner regions and interval linearizations for global optimization, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00648085
Upper bounding in inner regions for global optimization under inequality constraints, Journal of Global Optimization, vol.103, issue.2, pp.145-164, 2014. ,
DOI : 10.1007/s10107-005-0581-8
URL : https://hal.archives-ouvertes.fr/hal-00733860
Constraints -9 + ( -1 + q1 ) ^2 + ( -1 + x1 ) ^2=0; end Appendix B.2. Minibex code for ? Constants dmax =0.07; Variables x1 in [2. ,3.]; q1 in [3. ,4.]; d1 in [ -dmax , dmax ], 2005. ,
