Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
Model-Based Co-clustering for Functional Data
yosra Ben Slimen 1, 2 Sylvain Allio 1 Julien Jacques 3, 2
3 MODAL - MOdel for Data Analysis and Learning
LPP - Laboratoire Paul Painlevé - UMR 8524, Université de Lille, Sciences et Technologies, Inria Lille - Nord Europe, METRICS - Evaluation des technologies de santé et des pratiques médicales - ULR 2694, Polytech Lille - École polytechnique universitaire de Lille
Abstract : In order to provide a simplified representation of key performance indicators for an easier analysis by mobile network maintainers, a model-based co-clustering algorithm for functional data is proposed. Co-clustering aims to identify block patterns in a data set from a simultaneous clustering of rows and columns. The algorithm relies on the latent block model in which each curve is identified by its functional principal components that are modeled by a multivariate Gaussian distribution whose parameters are block-specific. These latter are estimated by a stochastic EM algorithm embedding a Gibbs sampling. In order to select the numbers of row-and column-clusters, an ICL-BIC criterion is introduced. In addition to be the first co-clustering algorithm for functional data, the advantage of the proposed model is its ability to extract the hidden double structure induced by the data and its ability to deal with missing values. The model has proven its efficiency on simulated data and on a real data application that helps to optimize the topology of 4G mobile networks.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01422756
Contributor : Julien Jacques Connect in order to contact the contributor
Submitted on : Monday, December 26, 2016 - 10:08:27 PM
Last modification on : Friday, April 15, 2022 - 3:00:04 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 1:15:59 PM
File
coclustering_functional_data.p...
Identifiers
Citation
yosra Ben Slimen, Sylvain Allio, Julien Jacques. Model-Based Co-clustering for Functional Data. Neurocomputing, Elsevier, 2018, 291, pp.97-108. ⟨10.1016/j.neucom.2018.02.055⟩. ⟨hal-01422756⟩
Share
Metrics
Record views
478
Files downloads
369
