Decentralized Asynchronous Crash-Resilient Runtime Verification
Runtime Verification (RV) is a lightweight method for monitoring the formal
specification of a system during its execution. It has recently been shown that
a given state predicate can be monitored consistently by a set of crash-prone
asynchronous \emph{distributed} monitors, only if sufficiently many different
verdicts can be emitted by each monitor. We revisit this impossibility result
in the context of \LTL semantics for RV. We show that employing the four-valued
logic \RVLTL will result in inconsistent distributed monitoring for some
formulas. Our first main contribution is a family of logics, called \LTLk, that
refines \RVLTL incorporating $2k + 4$ truth values, for each $k\geq 0$. The
truth values of \LTLk\/ can be effectively used by each monitor to reach a
consistent global set of verdicts for each given formula, provided $k$ is
sufficiently large. Our second main contribution is an algorithm for monitor
construction enabling fault-tolerant distributed monitoring based on the
aggregation of the individual verdicts by each monitor.
