Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
A scalable algebraic method to infer quadratic invariants of switched systems
Abstract : We present a new numerical abstract domain based on ellipsoids designed for the formal verification of switched linear systems. Unlike the existing approaches, this domain does not rely on a user-given template. We overcome the difficulty that ellipsoids do not have a lattice structure by exhibiting a canonical operator overapproximating the union. This operator is the only one that permits the performance of analyses that are invariant with respect to a linear transformation of state variables. It provides the minimum volume ellipsoid enclosing two given ellipsoids. We show that it can be computed in O(n3) elementary algebraic operations. We finally develop a fast nonlinear power-type algorithm, which allows one to determine sound quadratic invariants on switched systems in a tractable way, by solving fixed-point problems over the space of ellipsoids. We test our approach on several benchmarks, and compare it with the standard techniques based on linear matrix inequalities, showing an important speedup on typical instances.
Complete list of metadata
https://hal.inria.fr/hal-01423744
Contributor : Stephane Gaubert Connect in order to contact the contributor
Submitted on : Saturday, December 31, 2016 - 1:03:32 PM
Last modification on : Friday, February 4, 2022 - 3:22:39 AM
Identifiers
Citation
Xavier Allamigeon, Stéphane Gaubert, Eric Goubault, Sylvie Putot, Nikolas Stott. A scalable algebraic method to infer quadratic invariants of switched systems. ACM Transactions on Embedded Computing Systems (TECS), ACM, 2016, Special Issue on ESWEEK2015, 15 (4), ⟨10.1145/2932187⟩. ⟨hal-01423744⟩
Share
Metrics
Record views
312
