Size-based termination of higher-order rewriting
We provide a general and modular criterion for the termination of simply-typed λ -calculus extended with function symbols defined by user-defined rewrite rules. Following a work of Hughes, Pareto and Sabry for functions defined with a fixpoint operator and pattern-matching, several criteria use typing rules for bounding the height of arguments in function calls. In this paper, we extend this approach to rewriting-based function definitions and more general user-defined notions of size.
main.pdf (818.54 Ko)
Télécharger le fichier
jfp.bst (31.21 Ko)
