Superword Level Parallelism aware Word Length Optimization - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
Many embedded processors do not support floating-point arithmetic in order to comply with strict cost and power consumption constraints. But, they generally provide support for SIMD as a mean to improve performance for little cost overhead. Achieving good performance when targeting such processors requires the use of fixed-point arithmetic and efficient exploitation of SIMD data-path. To reduce time-to-market, automatic SIMDization – such as superword level parallelism (SLP) extraction – and float-to-fixed-point conversion methodologies have been proposed. In this paper we show that applying these transformations independently is not efficient. We propose a SLP-aware word length optimization algorithm to jointly perform float-to-fixed-point conversion and SLP extraction. We implement the proposed approach in a source-to-source compiler framework and evaluate it on several embedded processors. Experimental results illustrate the validity of our approach.
main.pdf (575.62 Ko) Télécharger le fichier
Dates and versions
hal-01425550 , version 1 (03-01-2017)
Identifiers
  • HAL Id : hal-01425550 , version 1
Cite
Ali Hassan El Moussawi, Steven Derrien. Superword Level Parallelism aware Word Length Optimization. Design, Automation & Test in Europe Conference & Exhibition (DATE 2017), Mar 2017, Lausanne, Switzerland. ⟨hal-01425550⟩
209 View
202 Download
Share
