Journal articles
Automatic Storage Optimization for Arrays
Somashekaracharya G Bhaskaracharya 1 Uday Bondhugula 1 Albert Cohen 2
2 Parkas - Parallélisme de Kahn Synchrone
DI-ENS - Département d'informatique - ENS Paris, Inria Paris-Rocquencourt, CNRS - Centre National de la Recherche Scientifique : UMR 8548
Abstract : Efficient memory allocation is crucial for data-intensive applications as a smaller memory footprint ensures better cache performance and allows one to run a larger problem size given a fixed amount of main memory. In this paper, we describe a new automatic storage optimization technique to minimize the dimensionality and storage requirements of arrays used in sequences of loop nests with a predetermined schedule. We formulate the problem of intra-array storage optimization as one of finding the right storage partitioning hyperplanes: each storage partition corresponds to a single storage location. Our heuristic is driven by a dual objective function that minimizes both, the dimensionality of the mapping and the extents along those dimensions. The technique is dimension optimal for most codes encountered in practice. The storage requirements of the mappings obtained also are asymptotically better than those obtained by any existing schedule-dependent technique. Storage reduction factors and other results we report from an implementation of our technique demonstrate its effectiveness on several real-world examples drawn from the domains of image processing, stencil computations, high-performance computing, and the class of tiled codes in general .
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01425564
Contributor : Albert Cohen Connect in order to contact the contributor
Submitted on : Tuesday, January 3, 2017 - 4:08:42 PM
Last modification on : Thursday, March 17, 2022 - 10:08:45 AM
Long-term archiving on: : Tuesday, April 4, 2017 - 2:40:16 PM
File
paper.pdf
Identifiers
Collections
Citation
Somashekaracharya G Bhaskaracharya, Uday Bondhugula, Albert Cohen. Automatic Storage Optimization for Arrays. ACM Transactions on Programming Languages and Systems (TOPLAS), ACM, 2016, 38, pp.1 - 23. ⟨10.1145/2845078⟩. ⟨hal-01425564⟩
Share
Metrics
Record views
310
Files downloads
296
