A Column Generation Based Heuristic for the Dial-A-Ride Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Dial-a-Ride Problem is a variant of the pickup and delivery problem with time windows, where the user inconvenience must be taken into account. In this paper, ride time and customer waiting time are modeled through both constraints and an associated penalty in the objective function. We develop a column generation approach, dynamically generating feasible vehicle routes. Handling ride time constraints explicitly in the pricing problem solver requires specific developments. Our dynamic programming approach for pricing problem makes use of a heuristic dominance rule and a heuristic enumeration procedure, which in turns implies that our overall branch-and-price procedure is a heuris-tic. However, in practice our heuristic solutions are experimentally very close to exact solutions and our approach is numerically competitive in terms of computation times.
ILSDarpHeu20.pdf (133.82 Ko) Télécharger le fichier
hal-01425755 , version 1 (03-01-2017)
  • HAL Id : hal-01425755 , version 1
Nastaran Rahmani, Boris Detienne, Ruslan Sadykov, François Vanderbeck. A Column Generation Based Heuristic for the Dial-A-Ride Problem. International Conference on Information Systems, Logistics and Supply Chain (ILS), Jun 2016, Bordeaux, France. ⟨hal-01425755⟩
503 Consultations
301 Téléchargements
