Conference papers
Interactive visualization of cross-layer performance anomalies in dynamic task-parallel applications and systems
Andi Drebes 1 Antoniu Pop 1 Karine Heydemann 2 Albert Cohen 3
2 ALSOC - Architecture et Logiciels pour Systèmes Embarqués sur Puce
LIP6 - Laboratoire d'Informatique de Paris 6
3 Parkas - Parallélisme de Kahn Synchrone
DI-ENS - Département d'informatique - ENS Paris, CNRS - Centre National de la Recherche Scientifique, Inria de Paris
Abstract : This paper studies the interactive visualization and post-mortem analysis of execution traces generated by task-parallel programs. We focus on the detection of performance anomalies inaccessible to state-of-the-art performance analysis techniques, including anomalies deriving from the interaction of multiple levels of software abstractions, anomalies associated with the hardware, and anomalies resulting from interferences between optimizations in the application and run-time system. Building on our practical experience with the performance debugging of representative task-parallel applications and run-time systems for dynamic dependent task graphs, we designed a new tool called Aftermath. This tool enables the visualization of intricate anomalies involving multiple layers and components in the system. It also supports filtering, aggregation and joint visualization of key metrics and performance indicators, such as task duration, run-time state, hardware performance counters and data transfers. The tool also relates this information to the machine's topology. While not specifically designed for non-uniform memory access (NUMA) architectures, Aftermath takes advantage of the explicit memory regions and dependence information in dependent task models to precisely capture long-distance and inter-core effects. Aftermath supports traces of up to several gigabytes, with fast and intuitive navigation and the on-line configuration of new derived metrics. As it has proven invaluable to optimize both run-time environments and applications, we illustrate Aftermath on genuine cases encountered in the OpenStream project.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01425892
Contributor : Albert Cohen Connect in order to contact the contributor
Submitted on : Wednesday, January 4, 2017 - 12:30:11 AM
Last modification on : Friday, January 21, 2022 - 3:17:05 AM
Long-term archiving on: : Wednesday, April 5, 2017 - 1:13:14 PM
File
paper.pdf
Identifiers
Citation
Andi Drebes, Antoniu Pop, Karine Heydemann, Albert Cohen. Interactive visualization of cross-layer performance anomalies in dynamic task-parallel applications and systems. IEEE International Symposium on Performance Analysis of Systems and Software (ISPASS), Apr 2016, Uppsala, Sweden. pp.274 - 283, ⟨10.1109/ISPASS.2016.7482102⟩. ⟨hal-01425892⟩
Share
Metrics
Les métriques sont temporairement indisponibles
