Transaction Parameterized Dataflow: A Model for Context-Dependent Streaming Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Static dataflow programming models are well suited to the development of embedded many-core systems. However, complex signal and media processing applications often display dynamic behavior that do not fit the classical static restrictions. We propose Transaction Parameterized Dataflow (TPDF), a new model of computation combining integer parameters—to express dynamic rates—and a new type of control actor—to allow topology changes and time constraints enforcement. We present static analyses for liveness and bounded memory usage. We also introduce a static scheduling heuristic to map TPDF to massively parallel embedded platforms. We validate the model and associated methods using a cognitive radio application, demonstrating significant buffer size and performance improvements compared to state of the art models including Cyclo-Static Dataflow (CSDF).
date2016.pdf (356.59 Ko) Télécharger le fichier
hal-01425902 , version 1 (04-01-2017)
  • HAL Id : hal-01425902 , version 1
Xuan Khanh Do, Stephane Louise, Albert Cohen. Transaction Parameterized Dataflow: A Model for Context-Dependent Streaming Applications. Design, Automation & Test in Europe Conference & Exhibition (DATE), Mar 2016, Dresden, Germany. ⟨hal-01425902⟩
203 Consultations
179 Téléchargements
