Nonparametric prediction in the multivariate spatial context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Nonparametric Statistics Année : 2016
This paper investigates a nonparametric spatial predictor of a stationary multidimensional spatial process observed over a rectangular domain. The proposed predictor depends on two kernels in order to control both the distance between observations and that between spatial locations. The uniform almost complete consistency and the asymptotic normality of the kernel predictor are obtained when the sample considered is an alpha-mixing sequence. Numerical studies were carried out in order to illustrate the behaviour of our methodology both for simulated data and for an environmental data set.
Fichier non déposé
hal-01425932 , version 1 (04-01-2017)
Sophie Dabo-Niang, Camille Ternynck, Anne-Françoise Yao. Nonparametric prediction in the multivariate spatial context. Journal of Nonparametric Statistics, 2016, 28 (2), pp.428-458. ⟨10.1080/10485252.2016.01.007⟩. ⟨hal-01425932⟩
234 Consultations
0 Téléchargements
