Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Downgrade Resilience in Key-Exchange Protocols
Abstract : Key-exchange protocols such as TLS, SSH, IPsec, and ZRTP are highly configurable, with typical deployments supporting multiple protocol versions, cryptographic algorithms and parameters. In the first messages of the protocol, the peers negotiate one specific combination: the protocol mode, based on their local configurations. With few notable exceptions, most cryptographic analyses of configurable protocols consider a single mode at a time. In contrast, downgrade attacks, where a network adversary forces peers to use a mode weaker than the one they would normally negotiate, are a recurrent problem in practice. How to support configurability while at the same time guaranteeing the preferred mode is negotiated? We set to answer this question by designing a formal framework to study downgrade resilience and its relation to other security properties of key-exchange protocols. First, we study the causes of downgrade attacks by dissecting and classifying known and novel attacks against widely used protocols. Second, we survey what is known about the downgrade resilience of existing standards. Third, we combine these findings to define downgrade security, and analyze the conditions under which several protocols achieve it. Finally, we discuss patterns that guarantee downgrade security by design, and explain how to use them to strengthen the security of existing protocols, including a newly proposed draft of TLS 1.3.
Complete list of metadata
https://hal.inria.fr/hal-01425962
Contributor : Bhargavan Karthikeyan Connect in order to contact the contributor
Submitted on : Wednesday, January 4, 2017 - 9:27:27 AM
Last modification on : Wednesday, June 8, 2022 - 12:50:04 PM
Identifiers
Collections
Citation
Karthikeyan Bhargavan, Chris Brzuska, Cédric Fournet, Matthew Green, Markulf Kohlweiss, et al.. Downgrade Resilience in Key-Exchange Protocols. IEEE Symposium on Security and Privacy (SP), 2016 , May 2016, San Jose, United States. ⟨10.1109/SP.2016.37⟩. ⟨hal-01425962⟩
Share
Metrics
Record views
101
