A changing-topology moving mesh technique for large displacements, Engineering with Computers, vol.222, issue.13, pp.175-200, 2014. ,
DOI : 10.1007/s00366-013-0340-z
URL : https://hal.archives-ouvertes.fr/hal-01114995
A parallel matrix-free conservative solution interpolation on unstructured tetrahedral meshes, Computer Methods in Applied Mechanics and Engineering, vol.299, pp.116-142, 2016. ,
DOI : 10.1016/j.cma.2015.10.012
URL : https://hal.archives-ouvertes.fr/hal-01211749
3D transient fixed point mesh adaptation for time-dependent problems: Application to CFD simulations, Journal of Computational Physics, vol.222, issue.2, pp.592-623, 2007. ,
DOI : 10.1016/j.jcp.2006.08.012
On the Use of Space Filling Curves for Parallel Anisotropic Mesh Adaptation, Proceedings of the 18th International Meshing Roundtable, pp.337-357, 2009. ,
DOI : 10.1007/978-3-642-04319-2_20
High-order sonic boom modeling based on adaptive methods, Journal of Computational Physics, vol.229, issue.3, pp.561-593, 2010. ,
DOI : 10.1016/j.jcp.2009.09.020
Multi-scale anisotropic mesh adaptation for time-dependent problems, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01339326
Extension of Metric-Based Anisotropic Mesh Adaptation to Time-Dependent Problems Involving Moving Geometries, 49th AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, 2011. ,
DOI : 10.2514/6.2011-896
Mesh adaptation by continuous deformation. basics: accuracy, efficiency, well balancedness, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01102124
Time-accurate anisotropic mesh adaptation for three-dimensional moving mesh problems, 2015. ,
DOI : 10.1016/j.jcp.2016.11.029
URL : https://hal.archives-ouvertes.fr/hal-01426156
Large displacement body-fitted FSI simulations using a mesh-connectivity-change moving mesh strategy, 44th AIAA Fluid Dynamics Conference, 2014. ,
DOI : 10.2514/6.2014-2773
URL : https://hal.archives-ouvertes.fr/hal-01113351
Two Mesh Deformation Methods Coupled with a Changing-connectivity Moving Mesh Method for CFD Applications, Proceedings of the 23th International Meshing Roundtable, 2014. ,
DOI : 10.1016/j.proeng.2014.10.385
URL : https://hal.archives-ouvertes.fr/hal-01113354
A new ALE adaptive unstructured methodology for the simulation of moving bodies, 32nd Aerospace Sciences Meeting and Exhibit, 1994. ,
DOI : 10.2514/6.1994-414
Time accurate anisotropic goal-oriented mesh adaptation for unsteady flows, Journal of Computational Physics, vol.231, issue.19, pp.6323-6348, 2012. ,
DOI : 10.1016/j.jcp.2012.05.003
URL : https://hal.archives-ouvertes.fr/hal-00940095
Anisotropic Error Estimates and Space Adaptivity for a Semidiscrete Finite Element Approximation of the Transient Transport Equation, SIAM Journal on Scientific Computing, vol.35, issue.2, pp.1192-1211, 2013. ,
DOI : 10.1137/120891320
Fast three dimensional r-adaptive mesh redistribution, Journal of Computational Physics, vol.275, pp.174-196, 2014. ,
DOI : 10.1016/j.jcp.2014.06.009
URL : http://centaur.reading.ac.uk/39193/1/paperdraft.pdf
An anisotropic, fully adaptive algorithm for the solution of convection-dominated equations with semi-Lagrangian schemes, Computer Methods in Applied Mechanics and Engineering, vol.273, pp.77-99, 2014. ,
DOI : 10.1016/j.cma.2014.01.025
Robust, multidimensional mesh-motion based on Monge???Kantorovich equidistribution, Journal of Computational Physics, vol.230, issue.1, pp.87-103, 2011. ,
DOI : 10.1016/j.jcp.2010.09.013
A mesh adaptation framework for dealing with large deforming meshes, Int. J. Numer. Meth. Engng, vol.82, issue.7, pp.843-867, 2010. ,
Adaptive time-step with anisotropic meshing for incompressible flows, Journal of Computational Physics, vol.241, pp.195-211, 2013. ,
DOI : 10.1016/j.jcp.2012.12.010
URL : https://hal.archives-ouvertes.fr/hal-01470576
Petrov-Galerkin solutions of the incompressible Navier-Stokes equations in primitive variables with adaptive remeshing, Computer Methods in Applied Mechanics and Engineering, vol.106, issue.1-2, pp.143-178, 1993. ,
DOI : 10.1016/0045-7825(93)90189-5
Anisotropic Delaunay Mesh Adaptation for Unsteady Simulations, Proceedings of the 17th International Meshing Roundtable, pp.177-194, 2008. ,
DOI : 10.1007/978-3-540-87921-3_11
URL : https://hal.archives-ouvertes.fr/hal-00353786
Anisotropic Level Set Adaptation for Accurate Interface Capturing, Proceedings of the 17th International Meshing Roundtable, pp.159-176, 2008. ,
DOI : 10.1007/978-3-540-87921-3_10
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.394.6500
Mesh generation. Application to finite elements, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00073738
Creation of internal points in Voronoi's type method. Control adaptation, Advances in Engineering Software and Workstations, vol.13, issue.5-6, pp.5-6303, 1991. ,
DOI : 10.1016/0961-3552(91)90034-2
An L???-Lp mesh-adaptive method for computing unsteady bi-fluid flows, International Journal for Numerical Methods in Engineering, vol.229, issue.1, pp.1376-1406, 2010. ,
DOI : 10.1002/nme.2954
A method for time accurate turbulent compressible fluid flow simulation with moving boundary components employing local remeshing, International Journal for Numerical Methods in Fluids, vol.193, issue.8, pp.531243-1266, 2007. ,
DOI : 10.1002/fld.1255
Computation of free-surface flows with local mesh adaptation, International Journal for Numerical Methods in Fluids, vol.33, issue.7, pp.785-816, 2005. ,
DOI : 10.1002/fld.1042
URL : https://hal.archives-ouvertes.fr/hal-00699456
Adaptive mesh movement ??? the MMPDE approach and its applications, Journal of Computational and Applied Mathematics, vol.128, issue.1-2, pp.383-398, 2001. ,
DOI : 10.1016/S0377-0427(00)00520-3
Adaptive remeshing for transient problems, Computer Methods in Applied Mechanics and Engineering, vol.75, issue.1-3, pp.195-214, 1989. ,
DOI : 10.1016/0045-7825(89)90024-8
Three-dimensional fluid-structure interaction using a finite element solver and adaptive remeshing, Computing Systems in Engineering, vol.1, issue.2-4, pp.257-272, 1990. ,
DOI : 10.1016/0956-0521(90)90012-A
Numerical simulation of a shock interaction with complex geometry three-dimensional structures using a new adaptive Hrefinement scheme on unstructured grids, 28th AIAA Aerospace Sciences Meeting, 1990. ,
Three-dimensional store separation using a finite element solver and adaptive remeshing, 29th AIAA Aerospace Sciences Meeting, 1991. ,
Adaptiveh-refinement on 3D unstructured grids for transient problems, International Journal for Numerical Methods in Fluids, vol.1, issue.12, pp.1407-1419, 1992. ,
DOI : 10.1002/fld.1650141204
Adaptive embedded unstructured grid methods, International Journal for Numerical Methods in Engineering, vol.60, issue.3, pp.641-660, 2004. ,
DOI : 10.1002/nme.978
Continuous Mesh Framework Part I: Well-Posed Continuous Interpolation Error, SIAM Journal on Numerical Analysis, vol.49, issue.1, pp.38-60, 2011. ,
DOI : 10.1137/090754078
Continuous Mesh Framework Part II: Validations and Applications, SIAM Journal on Numerical Analysis, vol.49, issue.1, pp.61-86, 2011. ,
DOI : 10.1137/10078654X
Fully anisotropic goal-oriented mesh adaptation for 3D steady Euler equations, Journal of Computational Physics, vol.229, issue.8, pp.2866-2897, 2010. ,
DOI : 10.1016/j.jcp.2009.12.021
Achievement of Global Second Order Mesh Convergence for Discontinuous Flows with Adapted Unstructured Meshes, 18th AIAA Computational Fluid Dynamics Conference, pp.2007-4186, 2007. ,
DOI : 10.2514/6.2007-4186
Cavity-Based Operators for Mesh Adaptation, 51st AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, 2013. ,
DOI : 10.2514/6.2013-152
URL : https://hal.archives-ouvertes.fr/hal-00935363
ReALE: A reconnection-based arbitrary-Lagrangian???Eulerian method, Journal of Computational Physics, vol.229, issue.12, pp.4724-4761, 2010. ,
DOI : 10.1016/j.jcp.2010.03.011
Improved transient-fixed-point mesh adaptation using orthogonality-preserving metric intersection, 20th AIAA Computational Fluid Dynamics Conference, 2011. ,
Revisiting the Least-Squares Procedure for Gradient Reconstruction on Unstructured Meshes, 16th AIAA Computational Fluid Dynamics Conference, 2003. ,
DOI : 10.2514/6.2003-3986
Simulations of 6-DOF Motion with a Cartesian Method, 41st Aerospace Sciences Meeting and Exhibit, 1246. ,
DOI : 10.2514/6.2003-1246
Anisotropic metric-based mesh adaptation for unsteady CFD simulations involving moving geometries, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00739406
A New Changing-Topology ALE Scheme for Moving Mesh Unsteady Simulations., 49th AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, 2011. ,
DOI : 10.2514/6.2011-474
Tetrahedral mesh optimisation and adaptivity for steady-state and transient finite element calculations, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.29-30, pp.3771-3796, 2001. ,
DOI : 10.1016/S0045-7825(00)00294-2
Flow patterns around heart valves: A numerical method, Journal of Computational Physics, vol.10, issue.2, pp.252-271, 1972. ,
DOI : 10.1016/0021-9991(72)90065-4
A space???time adaptation scheme for unsteady shallow water problems, Mathematics and Computers in Simulation, vol.82, issue.12, pp.2929-2950, 2012. ,
DOI : 10.1016/j.matcom.2011.06.004
Spatial adaptation procedures on tetrahedral meshes for unsteady aerodynamic flow calculations, 31st Aerospace Sciences Meeting, pp.1243-1251, 1992. ,
DOI : 10.2514/6.1993-670
Anisotropic adaptive simulation of transient flows using discontinuous Galerkin methods, International Journal for Numerical Methods in Engineering, vol.107, issue.7, pp.899-923, 2005. ,
DOI : 10.1002/nme.1196
An adaptive remeshing strategy for flows with moving boundaries and fluid???structure interaction, International Journal for Numerical Methods in Engineering, vol.70, issue.9, pp.711009-1050, 2007. ,
DOI : 10.1002/nme.1971
A 3D UNSTRUCTURED MESH ADAPTATION ALGORITHM FOR TIME-DEPENDENT SHOCK-DOMINATED PROBLEMS, International Journal for Numerical Methods in Fluids, vol.32, issue.1, pp.81-104, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19970715)25:1<81::AID-FLD541>3.0.CO;2-0
A New Class of Optimal High-Order Strong-Stability-Preserving Time Discretization Methods, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.469-491, 2002. ,
DOI : 10.1137/S0036142901389025
Error estimation and adaptivity in Navier-Stokes incompressible flows, Computational Mechanics, vol.26, issue.4, pp.259-270, 1990. ,
DOI : 10.1007/BF00370106
