Journal articles
A parallel matrix-free conservative solution interpolation on unstructured tetrahedral meshes
Frédéric Alauzet 1
1 Gamma3 - Automatic mesh generation and advanced methods
ICD - Institut Charles Delaunay, Inria Saclay - Ile de France
Abstract : This document presents an interpolation operator on unstructured tetrahedral meshes that satisfies the properties of mass conservation, P1P1-exactness (order 2) and maximum principle. Interpolation operators are important for many applications in scientific computing. For instance, in the context of anisotropic mesh adaptation for time-dependent problems, the interpolation stage becomes crucial as the error due to solution transfer accumulates throughout the simulation. This error can eventually spoil the overall solution accuracy. When dealing with conservation laws in CFD, solution accuracy requires enforcement of mass preservation throughout the computation, in particular in long time scale computations. In the proposed approach, the conservation property is achieved by local mesh intersection and quadrature formulae. Derivatives reconstruction is used to obtain a second order method. Algorithmically, our goal is to design a method which is robust and efficient. The robustness is mandatory to obtain a reliable method on real-life applications and to apply the operator to highly anisotropic meshes. The efficiency is achieved by designing a matrix-free operator which is highly parallel. A multi-thread parallelization is given in this work. Several numerical examples are presented to illustrate the efficiency of the proposed approach.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01426163
Contributor : Frédéric Alauzet Connect in order to contact the contributor
Submitted on : Tuesday, January 17, 2017 - 2:24:59 PM
Last modification on : Friday, February 4, 2022 - 3:31:34 AM
Long-term archiving on: : Tuesday, April 18, 2017 - 2:11:58 PM
File
PrePrint_Alauzet_A parallel ma...
Identifiers
Citation
Frédéric Alauzet. A parallel matrix-free conservative solution interpolation on unstructured tetrahedral meshes. Computer Methods in Applied Mechanics and Engineering, Elsevier, 2016, 299, pp.26. ⟨10.1016/j.cma.2015.10.012⟩. ⟨hal-01426163⟩
Share
Metrics
Record views
101
Files downloads
119
