A Galerkin projection method for mixed finite elements, IEEE Transactions on Magnetics, vol.35, issue.3, pp.1438-1441, 1999. ,
DOI : 10.1109/20.767236
Common-refinement-based data transfer between non-matching meshes in multiphysics simulations, International Journal for Numerical Methods in Engineering, vol.16, issue.14, pp.61-75, 2004. ,
DOI : 10.1002/nme.1147
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.135.6762
A Potential Enstrophy and Energy Conserving Numerical Scheme for Solution of the Shallow-Water Equations on a Geodesic Grid, Monthly Weather Review, vol.130, issue.5, pp.1397-1410, 2002. ,
DOI : 10.1175/1520-0493(2002)130<1397:APEAEC>2.0.CO;2
Some conservation issues for the dynamical cores of NWP and climate models, Journal of Computational Physics, vol.227, issue.7, pp.3715-3730, 2007. ,
DOI : 10.1016/j.jcp.2006.08.016
3D transient fixed point mesh adaptation for time-dependent problems: Application to CFD simulations, Journal of Computational Physics, vol.222, issue.2, pp.592-623, 2007. ,
DOI : 10.1016/j.jcp.2006.08.012
P1-conservative solution interpolation on unstructured triangular meshes, International Journal for Numerical Methods in Engineering, vol.27, issue.2, pp.1552-1588, 2010. ,
DOI : 10.1002/nme.2951
URL : https://hal.archives-ouvertes.fr/inria-00354509
Conservative interpolation between unstructured meshes via supermesh construction, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.33-36, pp.33-36, 2009. ,
DOI : 10.1016/j.cma.2009.03.004
Conservative interpolation on unstructured polyhedral meshes: An extension of the supermesh approach to cell-centered finite-volume variables, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.41-44, pp.41-44, 2011. ,
DOI : 10.1016/j.cma.2011.04.025
Conservative interpolation between volume meshes by local Galerkin projection, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.1-4, pp.1-4, 2011. ,
DOI : 10.1016/j.cma.2010.07.015
Delaunay triangulation and meshing. Application to finite elements, 1998. ,
Conservative Remapping and Region Overlays by Intersecting Arbitrary Polyhedra, Journal of Computational Physics, vol.148, issue.2, pp.433-466, 1999. ,
DOI : 10.1006/jcph.1998.6125
3D game engine design: a practical approach to real-time computer graphics (The Morgan Kaufmann Series in Interactive 3D Technology, 2006. ,
Mesh generation. Application to finite elements, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00073738
Robust, Vectorized Search Algorithms for Interpolation on Unstructured Grids, Journal of Computational Physics, vol.118, issue.2, pp.380-387, 1995. ,
DOI : 10.1006/jcph.1995.1107
The problems of accuracy and robustness in geometric computation, Computer, vol.22, issue.3, pp.31-39, 1989. ,
DOI : 10.1109/2.16223
LOCAL ROBUSTNESS AND ITS APPLICATION TO POLYHEDRAL INTERSECTION, International Journal of Computational Geometry & Applications, vol.04, issue.01, pp.87-118, 1994. ,
DOI : 10.1142/S0218195994000070
Convex Hull Computations, pp.495-512, 2004. ,
DOI : 10.1201/9781420035315.pt3
Mathematical Models, 1989. ,
The pleasures of 'perp dot' products, in: Graphics Gems IV, Ch. II, vol.5, pp.138-148, 1994. ,
Delaunay's mesh of a convex polygon in dimension d. Application to arbitrary polyedra, Int. J. Numer. Meth, pp.33-975, 1992. ,
On the Use of Space Filling Curves for Parallel Anisotropic Mesh Adaptation, Proceedings of the 18th International Meshing Roundtable, pp.337-357, 2009. ,
DOI : 10.1007/978-3-642-04319-2_20
Anisotropic mesh adaption by metric-driven optimization, International Journal for Numerical Methods in Engineering, vol.60, issue.3, pp.60-597, 2004. ,
DOI : 10.1002/nme.977
Anisotropic mesh adaptation in computational fluid dynamics: Application to the advection???diffusion???reaction and the Stokes problems, Applied Numerical Mathematics, vol.51, issue.4, pp.511-533, 2004. ,
DOI : 10.1016/j.apnum.2004.06.007
Anisotropic mesh adaptation for CFD computations, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.48-49, 2005. ,
DOI : 10.1016/j.cma.2004.11.025
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.96.1294
3D tetrahedral, unstructured and anisotropic mesh generation with adaptation to natural and multidomain metric, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.48-49, 2005. ,
DOI : 10.1016/j.cma.2004.11.020
URL : https://hal.archives-ouvertes.fr/hal-00517639
Mesh adaptation by metric control for multi-scale phenomena and turbulence, 35th AIAA Aerospace Sciences Meeting and Exhibit, 1997. ,
DOI : 10.2514/6.1997-859
Tetrahedral mesh optimisation and adaptivity for steady-state and transient finite element calculations, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.29-30, pp.190-3771, 2001. ,
DOI : 10.1016/S0045-7825(00)00294-2
Continuous Mesh Framework Part I: Well-Posed Continuous Interpolation Error, SIAM Journal on Numerical Analysis, vol.49, issue.1, pp.38-60, 2011. ,
DOI : 10.1137/090754078
Contributions aux méthodes numériques pour l'adaptation de maillage et le maillage mobile, HabilitationàHabilitation`Habilitationà Diriger des Recherches, 2012. ,
Size gradation control of anisotropic meshes, Finite Elements in Analysis and Design, vol.46, issue.1-2, pp.181-202, 2010. ,
DOI : 10.1016/j.finel.2009.06.028
Anisotropic Adaptive Simulations in Aerodynamics, 48th AIAA Aerospace Sciences Meeting Including the New Horizons Forum and Aerospace Exposition, 2010. ,
DOI : 10.2514/6.2010-169
URL : https://hal.archives-ouvertes.fr/hal-00935369
Serial and Parallel Mesh Modification Through a Unique Cavity-Based Primitive, Proceedings of the 22th International Meshing Roundtable, pp.541-558, 2013. ,
DOI : 10.1007/978-3-319-02335-9_30
URL : https://hal.archives-ouvertes.fr/hal-00935356
