Abstract : In this paper we define the flexibility of a system as its capability to schedule a new task. We present an approach to quantify the flexibility of a system. More importantly, we show that it is possible under certain conditions to identify the task that will directly induce the limitations on a possible software update. If performed at design time, such a result can be used to adjust the system design by giving more slack to the limiting task. We illustrate how these results apply to a simple system.
Type de document :
Communication dans un congrès
10th Junior Researcher Workshop on Real-Time Computing , Oct 2016, Brest, France
https://hal.inria.fr/hal-01426658
Contributeur : Sophie Quinton
Soumis le : jeudi 5 janvier 2017 - 17:29:05
Dernière modification le : mercredi 11 avril 2018 - 01:52:14
Document(s) archivé(s) le : jeudi 6 avril 2017 - 14:39:19
Rafik Henia, Alain Girault, Christophe Prévot, Sophie Quinton, Laurent Rioux. Quantifying the Flexibility of Real-Time Systems. 10th Junior Researcher Workshop on Real-Time Computing , Oct 2016, Brest, France. 〈hal-01426658〉
