Combining dynamic programming with filtering to solve a four-stage two-dimensional guillotine-cut bounded knapsack problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Optimization Année : 2018
The two-dimensional knapsack problem consists in packing a set of small rectangular items into a given large rectangle while maximizing the total reward associated with selected items. We restrict our attention to packings that emanate from a k-stage guillotine-cut process. We introduce a generic model where a knapsack solution is represented by a flow in a directed acyclic hypergraph. This hypergraph model derives from a forward labeling dynamic programming recursion that enumerates all non-dominated feasible cutting patterns. To reduce the hypergraph size, we make use of further dominance rules and a filtering procedure based on Lagrangian reduced costs fixing of hyperarcs. Our hypergraph model is (incrementally) extended to account for explicit bounds on the number of copies of each item. Our exact forward labeling algorithm is numerically compared to solving the max-cost flow model in the base hyper-graph with side constraints to model production bounds. Benchmarks are reported on instances from the literature and on datasets derived from a real-world application.
article.pdf (503.58 Ko) Télécharger le fichier
hal-01426690 , version 1 (04-01-2017)
François Clautiaux, Ruslan Sadykov, François Vanderbeck, Quentin Viaud. Combining dynamic programming with filtering to solve a four-stage two-dimensional guillotine-cut bounded knapsack problem. Discrete Optimization, 2018, 29, pp.18-44. ⟨10.1016/j.disopt.2018.02.003⟩. ⟨hal-01426690⟩
438 Consultations
760 Téléchargements
