Reports
Use of A Network Enabled Server System for a Sparse Linear Algebra Grid Application
Abstract : Solving systems of linear equations is one of the key operations in linear algebra. Many different algorithms are available in that purpose. These algorithms require a very accurate tuning to minimise runtime and memory consumption. The TLSE project provides, on one hand, a scenario-driven expert site to help users choose the right algorithm according to their problem and tune accurately this algorithm, and, on the other hand, a test-bed for experts in order to compare algorithms and define scenarios for the expert site. Both features require to run the available solvers a large number of times with many different values for the control parameters (and maybe with many different architectures). Currently, only the grid can provide enough computing power for this kind of application. The DIET middleware is the GRID backbone for TLSE. It manages the solver services and their scheduling in a scalable way.
Complete list of metadatas
https://hal.inria.fr/hal-01429873
Contributor : Eddy Caron <>
Submitted on : Monday, January 9, 2017 - 11:33:53 AM
Last modification on : Tuesday, September 8, 2020 - 9:38:05 AM
Identifiers
  • HAL Id : hal-01429873, version 1
Citation
Eddy Caron, Frédéric Desprez, Christophe Hamerling, Jean-Yves l'Excellent, Marc Pantel, et al.. Use of A Network Enabled Server System for a Sparse Linear Algebra Grid Application. [Research Report] RR-2005-30, LIP - ENS Lyon. 2005. ⟨hal-01429873⟩
Share
Metrics
Record views
371
