Switching Linear Inverse-Regression Model for Tracking Head Pose - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose to estimate the head-pose angles (pitch, yaw, and roll) by simultaneously predicting the pose parameters from observed high-dimensional feature vectors, and tracking these parameters over time. This is achieved by embedding a Gaussian mixture of linear inverse-regression model into a dynamic Bayesian model. The use of a switching Kalman filter (SKF) enables a principled way of carrying out this embedding. The SKF governs the temporal predic-tive distribution of the pose parameters (modeled as continuous latent variables) conditioned by the discrete variables associated with the mixture of linear inverse-regression formulation. We formally derive the equations of the proposed switching linear regression model, we propose an approximation that is both identifiable and computation-ally tractable, we design an EM procedure to estimate the SKF parameters in closed-form, and we carry out experiments and comparisons with other methods using recently released datasets.
submission_review.pdf (5.36 Mo) Télécharger le fichier
Format : Figure, Image
hal-01430727 , version 1 (10-01-2017)
Vincent Drouard, Sileye Ba, Radu Horaud. Switching Linear Inverse-Regression Model for Tracking Head Pose. IEEE Winter Conference on Applications of Computer Vision, Mar 2017, Santa Rosa, CA, United States. pp.1232-1240, ⟨10.1109/WACV.2017.142⟩. ⟨hal-01430727⟩
566 Consultations
322 Téléchargements
