Strategic positioning of the order penetration point, International Journal of Production Economics, vol.85, issue.3, pp.319-329, 2003. ,
DOI : 10.1016/S0925-5273(03)00119-1
Lean manufacturing on make-toorder suppliers: a case study, 12th International Conference on Industrial Engineering and Operations Management (ICIEOM), 2006. ,
Implementing Lean in Engineer-to-Order Manufacturing, p.148, 2014. ,
DOI : 10.4018/978-1-4666-5039-8.ch008
Creating mixed model value streams: practical lean techniques for building to demand, 2013. ,
Learning to see: value stream mapping to add value and eliminate muda, 2003. ,
Planning and implementing POLCA: a card-based control system for high variety or custom engineered products. Production planning and control, pp.596-610, 2009. ,
DOI : 10.1080/09537280903034297
A new value stream mapping approach for complex production systems, International Journal of Production Research, vol.7, issue.18-19, pp.18-19, 2006. ,
DOI : 10.1108/09576060310459429
URL : https://hal.archives-ouvertes.fr/hal-00512904
Value network mapping (VNM): visualization and analysis of multiple flows in value stream maps, Proceedings of the Lean Management Solutions Conference, 2001. ,
Value stream mapping for make-to-order products in a job shop environment, Construction Research Congress, 2005. ,
Value stream mapping adapted to high-mix, low-volume manufacturing environments, 2012. ,
Value stream mapping (VSM) in a manufacture-to-order small and medium enterprise, 2008. ,
Pacemaker, Bottleneck and Order Decoupling Point in Lean Production Systems, International Journal of Industrial Engineering: Theory, Applications and Practice, vol.16, issue.4, 2009. ,
A lean production control system for highvariety/low-volume environments: a case study implementation. Production Planning and Control, pp.586-595, 2009. ,
Enterprise reengineering?a strategic framework and methodology, 2005. ,
Integrating production and engineering perspectives on the customer order decoupling point, International Journal of Operations & Production Management, vol.25, issue.7, pp.623-641, 2005. ,
DOI : 10.1108/01443570510605072
Value stream mapping in a make-to-order environment, 2005. ,
Made-to-order lean: excelling in a high-mix, low-volume environment, 2007. ,
The lean toolbox for service systems, 2008. ,
The use of a multiple attribute decision-making method and value stream mapping in solving the pacemaker location problem, International Journal of Production Research, vol.30, issue.10, pp.49-2793, 2011. ,
DOI : 10.1016/j.rcim.2005.12.002
Leveling of low volume and high mix production based on a Group Technology approach, CIRP Journal of Manufacturing Science and Technology, vol.4, issue.3, pp.247-251, 2011. ,
DOI : 10.1016/j.cirpj.2011.06.003
