Abstract : Ship design and construction involves numerous activities that have to be effectively performed, coordinated and integrated. Various elements can influence the effectiveness of the process due to projects’ large number of stakeholders and the high level of uncertainty. One of the most challenging issues is the delay in product delivery. However, the elements which might result to delay do not develop overnight and there might be early warning signals addressing that the delay, is likely to happen. This paper discusses that by following an early warning procedure, it will be possible to identify possible early warning signs of potential problems which might cause delay. These signs can provide an aid for the project team to take actions before the problem reaches its full impact, thus delaying the project delivery.
https://hal.inria.fr/hal-01431097 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, January 10, 2017 - 3:20:59 PM Last modification on : Tuesday, February 23, 2021 - 7:24:06 PM Long-term archiving on: : Tuesday, April 11, 2017 - 3:53:20 PM
Sara Haji-Kazemi, Emrah Arica, Marco Semini, Erlend Alfnes, Bjørn Andersen. Detecting Early Warning Signs of Delays in Shipbuilding Projects. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.215-222, ⟨10.1007/978-3-319-22759-7_25⟩. ⟨hal-01431097⟩
