A Quantitative Comparison of Bottleneck Detection Methods in Manufacturing Systems with Particular Consideration for Shifting Bottlenecks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christoph Roser
  • Fonction : Auteur
  • PersonId : 997823
Masaru Nakano
  • Fonction : Auteur
  • PersonId : 997824
There are numerous different bottleneck detection methods both in academia and in industry. However, most do not take the shifting of bottlenecks into account. This paper compares a number of methods, namely methods based on cycle times and utilizations, waiting times and queue lengths, the arrow method, the turning point method, the active period method, and the bottleneck walk. All methods are tested against two different manufacturing systems, a pseudo static system consisting of a static system that changes once halfway through the production run and is designed to have shifting bottlenecks, and a dynamic system that includes variations for a multitude of different processes.
346973_1_En_32_Chapter.pdf (251.95 Ko) Télécharger le fichier
hal-01431106 , version 1 (10-01-2017)
Paternité
Christoph Roser, Masaru Nakano. A Quantitative Comparison of Bottleneck Detection Methods in Manufacturing Systems with Particular Consideration for Shifting Bottlenecks. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.273-281, ⟨10.1007/978-3-319-22759-7_32⟩. ⟨hal-01431106⟩
235 Consultations
751 Téléchargements
