Guidelines for the Selection of FIFO Lanes and Supermarkets for Kanban-Based Pull Systems – When to Use a FIFO and When to Use a Supermarket - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christoph Roser
  • Fonction : Auteur
  • PersonId : 997823
Masaru Nakano
  • Fonction : Auteur
  • PersonId : 997824
Modern lean production systems most often use a pull-based production control, usually implemented as kanban or CONWIP. The material flow in pull systems is managed using both FIFO lanes and supermarkets as inventories, which are well described in academic literature. However, there is so far little guidance as for when to use a supermarket and when to use a FIFO lane. This paper aims to provide an exhaustive list of considerations regarding the selection of a supermarket or FIFO lane between processes. While the detailed decisions depend on the particularities of the system, a number of general recommendations and considerations can be made. To the best knowledge of the authors, no such effort has been undertaken before, and we believe that this summary of considerations is long overdue and of immense value for the practitioner.
346973_1_En_33_Chapter.pdf (132.62 Ko) Télécharger le fichier
hal-01431107 , version 1 (10-01-2017)
Paternité
Christoph Roser, Masaru Nakano. Guidelines for the Selection of FIFO Lanes and Supermarkets for Kanban-Based Pull Systems – When to Use a FIFO and When to Use a Supermarket. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.282-289, ⟨10.1007/978-3-319-22759-7_33⟩. ⟨hal-01431107⟩
122 Consultations
1072 Téléchargements
