Abstract : The side negative effects of Lean Management implementations are well known among practitioners. Recently they became a subject of systematic research. This paper presents conclusions from a causal analysis of the unlikely results, which were identified along case studies. The research was conducted in the machine building industries in EU. The insights from interviews and expert-panels were systemized by cause-and-effect models, thus suggesting the root causes of the negative effects. The synthetized results are considered herein as an input for constructing a method for multi-perspective assessment, to enable better planning and control of the Lean Management implementations.
https://hal.inria.fr/hal-01431108 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, January 10, 2017 - 3:21:21 PM Last modification on : Thursday, March 5, 2020 - 4:45:10 PM Long-term archiving on: : Tuesday, April 11, 2017 - 3:43:26 PM
Andreas Mueller, Stanisław Strzelczak. Negative Side Effects of Lean Management Implementations – A Causal Analysis. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.290-298, ⟨10.1007/978-3-319-22759-7_34⟩. ⟨hal-01431108⟩
