A Framework for Cloud Manufacturing Enabled Optimisation for Machining - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nikolaos Tapoglou
  • Fonction : Auteur
  • PersonId : 997834
Jörn Mehnen
  • Fonction : Auteur
  • PersonId : 997835
Cloud Manufacturing is considered to be one of the paradigms that could revolutionize the way manufacturing has been realized in the industrial sector. Cloud Manufacturing services could be applied in most sectors of manufacturing since services can get integrated in the existing workflows. However, one of the most challenging while also most promising aspect is the reinterpretation of workflows and the creation of new workflows which could lead to more cost effective operations in the manufacturing industry. In this paper a framework for the optimization of cutting conditions in machining as part of a Cloud Manufacturing environment is presented. The aim of the framework is to provide users with an easier to use, cost efficient and well-informed solution that promotes sustainability in workshops. The main challenges, drivers and limitations in creating such an environment are discussed.
346973_1_En_42_Chapter.pdf (267.12 Ko) Télécharger le fichier
hal-01431117 , version 1 (10-01-2017)
Paternité
Nikolaos Tapoglou, Jörn Mehnen. A Framework for Cloud Manufacturing Enabled Optimisation for Machining. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2015, Tokyo, Japan. pp.363-370, ⟨10.1007/978-3-319-22759-7_42⟩. ⟨hal-01431117⟩
83 Consultations
141 Téléchargements
