New interface
Journal articles
A Unique Transformation from Ordinary Differential Equations to Reaction Networks
Abstract : Many models in Systems Biology are described as a system of Ordinary Differential Equations, which allows for transient, steady-state or bifurcation analysis when kinetic information is available. Complementary structure-related qualitative analysis techniques have become increasingly popular in recent years, like qualitative model checking or pathway analysis (elementary modes, invariants, flux balance analysis, graph-based analyses, chemical organization theory, etc.). They do not rely on kinetic information but require a well-defined structure as stochastic analysis techniques equally do. In this article, we look into the structure inference problem for a model described by a system of Ordinary Differential Equations and provide conditions for the uniqueness of its solution. We describe a method to extract a structured reaction network model, represented as a bipartite multigraph, for example, a continuous Petri net (CPN), from a system of Ordinary Differential Equations (ODEs). A CPN uniquely defines an ODE, and each ODE can be transformed into a CPN. However, it is not obvious under which conditions the transformation of an ODE into a CPN is unique, that is, when a given ODE defines exactly one CPN. We provide biochemically relevant sufficient conditions under which the derived structure is unique and counterexamples showing the necessity of each condition. Our method is implemented and available; we illustrate it on some signal transduction models from the BioModels database. A prototype implementation of the method is made available to modellers at http://contraintes.inria.fr/,soliman/ode2pn.html, and the data mentioned in the ''Results'' section at http://contraintes.inria.fr/,soliman/ode2pn_data/. Our results yield a new recommendation for the import/export feature of tools supporting the SBML exchange format.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01431261
Contributor : Sylvain Soliman Connect in order to contact the contributor
Submitted on : Tuesday, January 10, 2017 - 5:19:47 PM
Last modification on : Saturday, June 25, 2022 - 9:10:31 PM
Long-term archiving on: : Tuesday, April 11, 2017 - 4:02:36 PM
File
journal.pone.0014284.PDF
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Sylvain Soliman, Monika Heiner. A Unique Transformation from Ordinary Differential Equations to Reaction Networks. PLoS ONE, 2010, 5 (12), pp.e14284. ⟨10.1371/journal.pone.0014284⟩. ⟨hal-01431261⟩
Share
Metrics
Record views
83
Files downloads
95
