Designing biomedical proteomics experiments: state-of-the-art and future perspectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Expert Review of Proteomics Année : 2016
With the current expanded technical capabilities to perform mass spectrometry-based biomedi-cal proteomics experiments, an improved focus on the design of experiments is crucial. As it is clear that ignoring the importance of a good design leads to an unprecedented rate of false discoveries which would poison our results, more and more tools are developed to help researchers designing proteomic experiments. In this review, we apply statistical thinking to go through the entire proteomics workflow for biomarker discovery and validation and relate the considerations that should be made at the level of hypothesis building, technology selection, experimental design and the optimization of the experimental parameters.
Manuscript_March2016_revision_final (1).pdf (281.16 Ko) Télécharger le fichier
hal-01431414 , version 1 (11-01-2017)
Evelyne Maes, Pieter Kelchtermans, Wout Bittremieux, Kurt de Grave, Sven Degroeve, et al.. Designing biomedical proteomics experiments: state-of-the-art and future perspectives. Expert Review of Proteomics, 2016, ⟨10.1586/14789450.2016.1172967⟩. ⟨hal-01431414⟩
305 Consultations
776 Téléchargements
