A Brief Evaluation of Icons in the First Reading of the European Parliament on COM (2012) 0011
We present the result of a small-scale test in which the participants failed to understand the graphic scheme as well as the pictographic parts of the icons appearing in the Annex to Article 13a of the European Parliament legislative resolution of 12 March 2014 on the Proposal for a regulation of the European Parliament and of the Council on the protection of individuals with regard to the processing of personal data and on the free movement of such data (General Data Protection Regulation), COM (2012) 0011.
Informatique [cs]
