A Projection Method on Measures Sets - Archive ouverte HAL Access content directly
Journal Articles Constructive Approximation Year : 2017
(1, 2) , (1, 2) , (3) , (3, 4)
1
2
3
4
We consider the problem of projecting a probability measure π on a set MN of Radon measures. The projection is defined as a solution of the following variational problem: inf µ∈M N h (µ − π) 2 2 , where h ∈ L 2 (Ω) is a kernel, Ω ⊂ R d and denotes the convolution operator. To motivate and illustrate our study, we show that this problem arises naturally in various practical image rendering problems such as stippling (representing an image with N dots) or continuous line drawing (representing an image with a continuous line). We provide a necessary and sufficient condition on the sequence (MN) N ∈N that ensures weak convergence of the projections (µ * N) N ∈N to π. We then provide a numerical algorithm to solve a discretized version of the problem and show several illustrations related to computer-assisted synthesis of artistic paintings/drawings.
Measure_Projection.pdf (18.75 Mo) Télécharger le fichier
Dates and versions
hal-01432720 , version 1 (12-01-2017)
Identifiers
Cite
Nicolas Chauffert, Philippe Ciuciu, Jonas Kahn, Pierre Weiss. A Projection Method on Measures Sets. Constructive Approximation, 2017, 45 (1), pp.83 - 111. ⟨10.1007/s00365-016-9346-2⟩. ⟨hal-01432720⟩
788 View
324 Download
Share
