Modal analysis identification techniques, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.359, issue.1778, pp.29-40, 1778. ,
DOI : 10.1098/rsta.2000.0712
Stochastic System Identification for Operational Modal Analysis: A Review, Journal of Dynamic Systems, Measurement, and Control, vol.123, issue.4, pp.659-667, 2001. ,
DOI : 10.1115/1.1410370
De Moor, Subspace Identification for Linear Systems: Theory, 1996. ,
Reference-based stochastic subspace identification for output-only modal analysis, Mechanical systems and signal processing, pp.855-878, 1999. ,
Nonstationary Consistency of Subspace Methods, IEEE Transactions on Automatic Control, vol.52, issue.6, pp.974-984, 2007. ,
DOI : 10.1109/TAC.2007.898970
Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012. ,
DOI : 10.1016/j.conengprac.2012.05.005
Uncertainty calculation in (operational) modal analysis, Mechanical systems and signal processing, pp.2359-2373, 2007. ,
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
DOI : 10.1016/j.ymssp.2007.10.009
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, issue.2, pp.346-366, 2013. ,
DOI : 10.1016/j.ymssp.2013.01.012
Dealing with uncertainty in model updating for damage assessment: A review, Mechanical Systems and Signal Processing, vol.56, issue.57, pp.123-149, 2015. ,
DOI : 10.1016/j.ymssp.2014.11.001
Finite element model updating in structural dynamics, 1995. ,
DOI : 10.1007/978-94-015-8508-8
The sensitivity method in finite element model updating: a tutorial, Mechanical systems and signal processing, pp.2275-2296, 2011. ,
Aleatory or epistemic? Does it matter?, Structural Safety, vol.31, issue.2, pp.105-112, 2009. ,
DOI : 10.1016/j.strusafe.2008.06.020
Perturbation methods for the estimation of parameter variability in stochastic model updating, Mechanical Systems and Signal Processing, vol.22, issue.8, pp.1751-1773, 2008. ,
DOI : 10.1016/j.ymssp.2008.03.001
A finite element-based subspace fitting approach for structure identification and damage localization, Mechanical Systems and Signal Processing, pp.58-59, 2015. ,
DOI : 10.1016/j.ymssp.2014.12.003
A subspace fitting method for identification of linear state-space models, Automatic Control, IEEE Transactions on, vol.40, issue.2, pp.311-316, 1995. ,
Numerical and experimental analysis of uncertainty on modal parameters estimated with the stochastic subspace method, Journal of Sound and Vibration, vol.333, issue.18, pp.4376-4401, 2014. ,
DOI : 10.1016/j.jsv.2014.04.039
Introduction to spectral analysis, 1997. ,
Separable nonlinear least squares: the variable projection method and its applications, Inverse Problems, vol.19, issue.2, p.1, 2003. ,
DOI : 10.1088/0266-5611/19/2/201
Gauss-Newton method, Wiley Interdisciplinary Reviews: Computational Statistics, vol.22, issue.4, pp.415-420, 2012. ,
DOI : 10.1002/wics.1202
Estimation of modal parameters and their uncertainties, Tech. rep, 1998. ,
Multiple time series (wiley series in probability and mathematical statistics) ,
Statistical inference, thomson learning ,
Kronecker products and matrix calculus in system theory, Circuits and Systems, IEEE Transactions on, vol.25, issue.9, pp.772-781, 1978. ,
DOI : 10.1109/tcs.1978.1084534
Discrete-time norms of flexible structures, Journal of Sound and Vibration, vol.264, issue.5, pp.983-1004, 2003. ,
DOI : 10.1016/S0022-460X(02)01184-7
Consistency and asymptotic normality of some subspace algorithms for systems without observed inputs, Automatica, vol.35, issue.7, pp.1243-1254, 1999. ,
DOI : 10.1016/S0005-1098(99)00031-X
